That1guy Posted December 27, 2014 Share Posted December 27, 2014 Lomg story short; bought a 98 2.5 gt with blown engine, did an engine swap but now the car has a billion electrical gremlens. The starter won't crank at all and while the key is in the ignition the fuse box under the hood clicks as well as the abs unit on passenger and all the interior lights do a corresponding flicker. I have no idea whats going on with this car and hope someone has some info to help me out with this. Link to comment Share on other sites More sharing options...
johnegg Posted December 28, 2014 Share Posted December 28, 2014 disconnect the battery. put the key in the ignition and turn it all the way to start. let go of the key . (it will turn back to the run position.) connect the battery. any time you install /connect a battery the remote entry / alarm system assumes you are stealing the car, unless you have the key in the run position. another thing to check are the green diagnostic connectors under the dash. they are supposed to be DIS-CONNECTED. Link to comment Share on other sites More sharing options...
subikid90 Posted January 4, 2015 Share Posted January 4, 2015 Also check to make sure the engine harness is connected all the way and the engine grounds are tight. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
