Joe Biju Jose Posted November 29, 2018 Share Posted November 29, 2018 My 2007 legacy automatic, sometimes shifts at 4000, 5000 rpms even if I continue to accelerate. The turbo kicks in and the rpm boosts up and at a very early point (5k rpm) it just stops accelerating and disengages the turbo which I recon happens with a shift in gear. The car throws itself after the gear shift which creates a rough jerk. When it shifts at around 7k rpm, the transmission is super smooth. Does anyone else face the issue? Know what it is? Sent from my Redmi Note 4X using Tapatalk Link to comment Share on other sites More sharing options...
gimpydingo Posted November 29, 2018 Share Posted November 29, 2018 Welcome to owning a 5EAT LGT. https://legacygt.com/forums/showthread.php/5eat-early-automatic-upshifts-manual-mode-207793.html Are you doing any logging? After I fixed all the vac leaks and such and a tune it's pretty rare it will jump gears now. If you can do some logging, check for leaks or any mechanical issues. Link to comment Share on other sites More sharing options...
