need bb Posted February 20, 2017 Share Posted February 20, 2017 My walbro 255 has served me well, but I will likely be upgrading to 1000cc injectors and E85 and I believe I will need a larger fuel pump. I am looking at the DW300c and Walbro 400 as replacement options, but I am concerned with the reliability of the DW based on some of the posts on the forum. Any feedback on which will be best? That leads me to my next question regarding upgrading the fuel pump wiring. I have read through Turkeylord's guide, but I am confused whether this just lowers the cable resistance to the fuel pump or if it also wires the fuel pump directly to the battery? If I purchase the DW fuel pump cable kit am I good or do I need to purchase separate relays? Thanks Link to comment Share on other sites More sharing options...
CapnJack Posted February 20, 2017 Share Posted February 20, 2017 I ran a 300c in my car and it worked great. I would certainly put another one in. They are designed to run on E85. That said, I think your 255 would be large enough to feed the 1000cc injectors. The 255 is rated for roughly 257 liters per hour at 40PSI. That would equate to 4.28 liters per minute. With 1000cc injectors, (assuming an average of 1000cc per minute times 4 injectors) you are only requiring 4 liters per minute. Should be fine if you want to keep it. With regards to the wiring, you are correct that it runs a cable from the battery to a relay, then through the fuel pump module, then to the pump. You upgrade the wire size to allow less voltage drop. The DW fuel pump kit is a nice unit and has most everything you need. You may need some extra wire depending on how you route. I assume you are talking about this: https://www.amazon.com/DeatschWerks-FPHWK-Fuel-Hardwire-Installation/dp/B009PJQFQA In addition, make sure you read the updates on the wiring in the Turkeylord thread. The original method allowed a small battery drain and would run the battery dead after a couple of weeks. The fix is in the thread and solve the battery drain issue. Link to comment Share on other sites More sharing options...
need bb Posted February 20, 2017 Author Share Posted February 20, 2017 Thanks for the insight. I am not 100% sure about the math, but I thought if I run 24psi and add this to the base fuel pressure, then the pump would only be flowing 225lph. Link to comment Share on other sites More sharing options...
CapnJack Posted February 20, 2017 Share Posted February 20, 2017 Do you have top feeds or are you staying with side feeds. The side feeds flow a little less. (~900cc) You could be getting close if you start to run IDCs above 90%. It would also depend on your boost taper towards redline. If you start to run out of injector up top, you can still have your low end punch and taper boost at the top end. What kind of engine mods do you have to run 24psi? If you don't already, you'd want to look at different head studs as the factory studs will stretch allowing the heads to lift around 21-22psi increasing your risk of blowing a head gasket or eating coolant. Link to comment Share on other sites More sharing options...
need bb Posted February 21, 2017 Author Share Posted February 21, 2017 I have an opportunity to pick up some DW sidefeeds for cheap which flow around 970cc. The top feed conversions kits are going to cost almost $1K all in which is more than I want to spend on the car. I have a built block with ARP2000 headstuds, and running a TD05-20G. I think with the 1000cc injectors my IDC would be 90-95%. Link to comment Share on other sites More sharing options...
CapnJack Posted February 21, 2017 Share Posted February 21, 2017 Nice! Sounds like a nice build! Link to comment Share on other sites More sharing options...
Gex Posted February 21, 2017 Share Posted February 21, 2017 Don't use big sidefeed injectors. They're a pain in the ass to tune and very unreliable. Pony up for the topfeed conversion. Link to comment Share on other sites More sharing options...
need bb Posted February 23, 2017 Author Share Posted February 23, 2017 Totally understand, but really don't really want to spend $1K on the topspeed conversion. It sounds like I am going to have to upgrade since the Walbro 255 can only really support around 220LPH when running 20+ psi of boost which would be less than the 1000cc injectors could support. My fuel pump assembly is already trimmed for the Walbro. Does the DW300c need trimming to fit? Link to comment Share on other sites More sharing options...
utc_pyro Posted February 23, 2017 Share Posted February 23, 2017 Dw300c, AEM 50-1215, Areomotive 325, and the eBay specials (with painted bodies and colored caps) are all no trimming plug and play. It's strongly suspected that all of the above are actually made in the same factory in China. They all perform the same down to power draw, just have minor differences in in seals/materials and QC. That said, if the filter was already hacked up they probably won't mate correctly. Get a new filter, they are about $40. It's 12 years old now and probably needs to be replaced any way. Link to comment Share on other sites More sharing options...
need bb Posted February 24, 2017 Author Share Posted February 24, 2017 The Aeromotive 340 looks nice and isn't that expensive. Since my fuel assembly was modded to fit the walbro 255 would this cause issues since the Aeromotive 340 is slightly smaller? Link to comment Share on other sites More sharing options...
utc_pyro Posted February 24, 2017 Share Posted February 24, 2017 Edit: the following is WRONG on the Areomotive 340, got it confused with the 325 drop in Yes, the Walbro 255 install involves hacking up the mounting ears for the pump inside the fuel filter. It's not so much a factor of size as it's a factor of the top of the Walbro had a different shape that nessetated removing those ears. You'll need a new fuel filter so the Areomotive pump can mount properly. USA made: 42072AG16A Japan made: 42072AG140 You'll want to put in new o-rings with that. USA made: 3x 42025AG09A 1x 42025AG10A Japan Made: 3x 42025AG070 1x 42025AG080 And your pick up strainer probably has seen better days. The Areomotive may come with one (designed for a Honda) but can get a new OEM with the proper shape for ~$5 USA made: Denso 952-0090 Japan made: Denso 952-0086 Edit: the Areomotive 340 is the same size as the Walbro, so requires the same mounting. Disregard the above unless going to a "drop in" style pump. Link to comment Share on other sites More sharing options...
CapnJack Posted February 24, 2017 Share Posted February 24, 2017 I had initially installed an Aeromotive 340 on my E85 LGT and as I recall, it was not a drop in pump. I had to modify the housing similar to the Walbro 255. I also had to modify the top of the pump. Below are the notes I followed when I did it. After about 6 months on E85, I started having fueling problems and pulled the pump. The outside of the pump had pockets of rust formed on it. I ultimately pulled it an went with a DW300C and never looked back. It was a true drop in pump and worked well. http://legacygt.com/forums/showthread.php/which-aeromotive-340i-171322.html?t=171322&highlight=aeromotive+340 http://www.iwsti.com/forums/2-5-liter-litre-factory-motor/223636-aeromotive-stealth-340-lph-direct-drop.html http://legacygt.com/forums/showthread.php/installed-aeromotive-340-fuel-pump-today-177995.html?t=177995&highlight=aeromotive+340 Link to comment Share on other sites More sharing options...
cryo Posted February 24, 2017 Share Posted February 24, 2017 The aem320 is my go to pump for anything in that power level. I would stay far away from high volume sidefeeds...i realize its expensive but there is a reason why people go that route for top feed conversion. I will NOT even calibrate anything larger than 850 side feeds due to inconsistencys in fueling/latencys and failure rate. Just my .02 as i know we have worked together in the past. Oherwise it sounds like you should have a fun build with the new block Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
CapnJack Posted February 24, 2017 Share Posted February 24, 2017 Nice! I didn't know AEM made that pump. Are they new to the market. (by new I mean within the last two years?) Link to comment Share on other sites More sharing options...
spec.B Dream Posted February 24, 2017 Share Posted February 24, 2017 FWIW, I've been running a Walbro 255 on 1000cc injectors (top feed, 3 years of DW and 2 of ID) with e85 and a BNR68 at 24 psi peak boost for 5 years now. Link to comment Share on other sites More sharing options...
cryo Posted February 24, 2017 Share Posted February 24, 2017 They (aem) supply a drop in fitment now for the lgt/08 wrx and i have had great luck with it. Got tired of seeing high rpm pressure drops of the 65c.....the walbro should support it as well, 255lph is a good amount of fuel. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
