E85: 20G with 850cc Injector
I recently moved to California and discovered an E85 station within 15 minutes. I am currently running a Walbro 255, DW8500cc injectors, and a TD05-20G.
I know I should ideally be on 1000cc injectors to maximize my setup, but is 850cc enough to still run E85 with lower boost? It seems like I would still be way better off than running pump 91.
Thanks
You need 1000cc injectors for this job and that's the right time to upgrade to top-feeds. Yes you can raise base fuel pressure by half a bar but this is a bandaid solution. If the pump isn't adequate flow will fall off as pressure rises and then you don't actually get more fuel flowing at peak revs.
Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs.
  • 4 weeks later...
I have done some reading and it seems that the ID1000's flow around 900cc. My DW850's flow at 860cc so wouldn't this be close enough?
Clearly I wouldn't be able to run 20+ PSI, but it seems that I could still pick up a lot of power by running higher timing with lower boost. It seems that 850cc would be good for around 350WHP on E85, which is a good bump from where I am on 91 today. If I go this route I would definitely need to rewire my fuel pump to get closer to 14v.
Thanks
I start tuning the ID1000s with a scalar at 880cc and the final values end up within about 5cc of that. If those modded 850s aren't enough then I'd step up to the DW1200 if you're tuning with OS tools or ID1300 if on Cobb.
My tuner had to taper to 15 in order to keep up with fueling.
You want to hold the VF-52 to right around 1bar at redline anyway as efficiency falls off a cliff beyond that. You're not leaving much on the table.
