landcrush Posted November 24, 2020 Share Posted November 24, 2020 Will post more detailed account but the gist is that I installed id1000s, then threw p0021 code, replaced AVCS solenoid, then threw P0340 cam code, and have cyl 2 and 4 misfire now. Driver exhaust cam gear appears to be off slightly but I’m not too sure. Link to comment Share on other sites More sharing options...
landcrush Posted November 24, 2020 Author Share Posted November 24, 2020 (edited) Trying to get to the bottom of my most recent subaru fueled headache. 08 specB built motor, just installed id1000s, upgrading from DW850s. Got a map sent from my tuner so I could get to the shop. Was all good until the car threw P0021 AVCS code. removed the solenoid to find it had broken in two, or rather the crimp had failed and the shaft was spinning freely. Got a replacement and installed it. Fired the car up and seemed to run like crap. Figured it was maybe the ecu relearn. But AFR went full lean on my wideband and threw P0340 cam code. Checked connections and pulled timing cover to check it out. Driver side exhaust cam gear looks to be slightly out. Now have Cyl 2 and 4 misfire. Wondering if oil got on the coils driver side causing misfire or I knocked something loose when pulling my inter cooler piping to get to the solenoid. Trying to upload image of cam gears from my phone Edited November 24, 2020 by landcrush Link to comment Share on other sites More sharing options...
