JJr Posted November 17, 2020 Share Posted November 17, 2020 Help please guys! I need to get this back together before my wife hears my wagon with a open DP, lol I'm matting up my OEM DP to my Greddy SP2 exhaust (60mm-2.36") I'll be changing the DP for a catted Cobb in the spring. I thought I could use a 3" 2x Grimspeed flat gasket but a local shop said it will leak if I don't use a Grimspeed adapter, 2x flat gasket with the OEM donut. After reading a thread Underdog says I should use the springs and bolts if I don't use have a flex joint at the end of the DP or at the beginning of the midpipe. Thank you all who chime in. Link to comment Share on other sites More sharing options...
whitetiger Posted November 18, 2020 Share Posted November 18, 2020 do what the local shop said, and use the spring bolts at the connection that uses the donut gasket. Link to comment Share on other sites More sharing options...
JJr Posted November 18, 2020 Author Share Posted November 18, 2020 Thanks to all. I spoke with Greddy, the local shop and Underdog (Rick) I'm going without the spring bolts but using the adapter! Link to comment Share on other sites More sharing options...
Max Capacity Posted November 19, 2020 Share Posted November 19, 2020 My wagon has had both, The Invidia Dp with the 3" 2X thick to stock midpipe was fine, I may have used the red RTV sealant to help. It currently has the Grimmspeed adaptor with the RTV, 3" 2X thick, no springs. I did the adaptor just because... I have not used springs at that joint for many, many years. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JJr Posted November 19, 2020 Author Share Posted November 19, 2020 Awesome, thx Max, if I get everything I need and some warm weather Sunday I'll be under her again. When I install my Cobb DP I think they should mate up fine without the adapter. Link to comment Share on other sites More sharing options...
JJr Posted November 25, 2020 Author Share Posted November 25, 2020 Grimmspeed OEM DP to Catback adapter, 2x gasket and oem donut worked great! Link to comment Share on other sites More sharing options...
