jdeitz1979 Posted October 15, 2016 Share Posted October 15, 2016 For some reason the radio signal is very weak. Like almost every station displays sounds of static. Not sure why, and have been looking for a fix, but it seems like this is more of a hatch back problem. Any info or pointers are greatly appreciated. I had checked my fuses and if in this case it does run the rear window I had checked that for breaks and bad wired plugging into it as well. Sent from my HTC6525LVW using Tapatalk Link to comment Share on other sites More sharing options...
WahooNo2 Posted October 15, 2016 Share Posted October 15, 2016 It could be the harness that connects the hatch door to the car. The wire in that harness may have broke from opening and closing. My rear wiper doesnt return to the 'home position' right because of something in that cable being broke. I never fixed it because there was always something bigger that i needed to work on or fix. Link to comment Share on other sites More sharing options...
WahooNo2 Posted October 15, 2016 Share Posted October 15, 2016 it may be this harness discussed in this thread http://legacygt.com/forums/showthread.php/walkthrough-replace-wagon-wire-harness-238160p2.html Link to comment Share on other sites More sharing options...
coldsoda Posted October 15, 2016 Share Posted October 15, 2016 Theres a handful of threads on here that might be helpful to you. Here's a couple good ones in addition to the one Wahoo posted. http://legacygt.com/forums/showthread.php/wagons-beware-tailgate-electricals-161086.html http://legacygt.com/forums/showthread.php/radio-reception-sucks-240606.html Link to comment Share on other sites More sharing options...
jdeitz1979 Posted October 16, 2016 Author Share Posted October 16, 2016 I have the 4 door lgt limited turbo. No hatch. This is my issue with finding a more definite answer. But, I did figure out that chargers in the cig power outlets contribute to static. Removed them and it's a lot better, but not completely gone Sent from my HTC6525LVW using Tapatalk Link to comment Share on other sites More sharing options...
jdeitz1979 Posted October 16, 2016 Author Share Posted October 16, 2016 it may be this harness discussed in this thread http://legacygt.com/forums/showthread.php/walkthrough-replace-wagon-wire-harness-238160p2.html This link only wants to open in chrome, and then force closes. Sent from my HTC6525LVW using Tapatalk Link to comment Share on other sites More sharing options...
WahooNo2 Posted October 16, 2016 Share Posted October 16, 2016 legacygt.com/forums/showthread.php/walkthrough-replace-wagon-wire-harness-238160p2.html odd i didnt do anything special. theres the full link do you have any amps in your trunk or radar detectors? Are you listening to fm or am i notice am is staticy for me and gets interference by powerlines try turning your cell phone off when you are in the car to see if its that gsm phones used to cause radio and speaker interferences Link to comment Share on other sites More sharing options...
jdeitz1979 Posted October 16, 2016 Author Share Posted October 16, 2016 Thanks. IDK why ur did that. I have had nothing but problems with this app since switching to an Android. No amps and FM only I listen to. Sent from my HTC6525LVW using Tapatalk Link to comment Share on other sites More sharing options...
relative4 Posted October 16, 2016 Share Posted October 16, 2016 Your antenna has two electronic components, an amplifier and a noise reducer. Either could cause your symptoms if faulty. I would check power to each of them, and check continuity in the antenna signal cable. If that's all good, I'd replace each of those components one at a time. You should be able to get both from a junkyard. http://parts.subaru.com/a/Subaru_2007_Legacy25L-TURBO-5MT-4WDGT-Limited-Sedan/_52016_6022269/AUDIO-PARTS-ANTENNA-ANTENNA/B13-863-01.html Link to comment Share on other sites More sharing options...
allwheeldrift Posted October 17, 2016 Share Posted October 17, 2016 so would this fix my problem if i get radio static everytime i turn on my defog? Link to comment Share on other sites More sharing options...
relative4 Posted October 17, 2016 Share Posted October 17, 2016 so would this fix my problem if i get radio static everytime i turn on my defog? No, that's a different problem. If your reception is fine with defog off and bad with defog on, your defogger has a scratched/cut wire somewhere on the rear window. You can find it with fine steel wool (makes sparks), or with a little portable radio with a long antenna. Then use a defogger repair kit from the auto parts store. Link to comment Share on other sites More sharing options...
JacksonJ Posted October 18, 2016 Share Posted October 18, 2016 I have the 4 door lgt limited turbo. No hatch. This is my issue with finding a more definite answer. But, I did figure out that chargers in the cig power outlets contribute to static. Removed them and it's a lot better, but not completely gone Sent from my HTC6525LVW using Tapatalk I have the same issue. My dash cam plugged into the cigarette lighter outlet causes the static. Removing it allows for radio but then no dash cam. Sent from my SGH-I527M using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted October 18, 2016 Share Posted October 18, 2016 I have the same issue. My dash cam plugged into the cigarette lighter outlet causes the static. Removing it allows for radio but then no dash cam. Sent from my SGH-I527M using Tapatalk IMO, find another place to power the dash cam. There should be power up above the rear view mirror in the headliner. Service manual will help you find it. http://people.csail.mit.edu/ilh/vacation/ 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
relative4 Posted October 18, 2016 Share Posted October 18, 2016 I have the same issue. My dash cam plugged into the cigarette lighter outlet causes the static. Removing it allows for radio but then no dash cam. Does that dash cam cause the same problem in other cars? If so, try a different dash cam. If not, check your noise reducer. Link to comment Share on other sites More sharing options...
