IdkWhatUserNameToUse Posted August 22, 2018 Share Posted August 22, 2018 Is it worth buying another quart to hit that 5.1 mark, or would one 5 quart jug be enough? Link to comment Share on other sites More sharing options...
boxkita Posted August 22, 2018 Share Posted August 22, 2018 .1 quart is about the size of the oil filter. If you prefill, then it works out. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
IdkWhatUserNameToUse Posted August 22, 2018 Author Share Posted August 22, 2018 .1 quart is about the size of the oil filter. If you prefill, then it works out. It’s hard to fill when you have to mount the filter on the engine though lol Link to comment Share on other sites More sharing options...
ammcinnis Posted August 22, 2018 Share Posted August 22, 2018 Is the .1 of the 5.1 quarts of oil a big difference? Not when the difference between the "Full" and "Add" marks on the dipstick is ~1 quart. "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
securityguy Posted August 23, 2018 Share Posted August 23, 2018 The answer is NO...just put in 5 quarts and call it a day. 0.1 quart is nothing and nothing to be concerned about. Filled with 5.0 for years and never an issue nor did I expect one. If anyone tells you different...don't listen to them:spin: Link to comment Share on other sites More sharing options...
moral hazard Posted August 23, 2018 Share Posted August 23, 2018 You always get more out of a jug than stated on the label anyway. Link to comment Share on other sites More sharing options...
ehsnils Posted August 26, 2018 Share Posted August 26, 2018 It's because you use quarts instead of liters. The vehicles are using metric measurements as standard. Link to comment Share on other sites More sharing options...
securityguy Posted August 26, 2018 Share Posted August 26, 2018 It's because you use quarts instead of liters. The vehicles are using metric measurements as standard. What:confused: Link to comment Share on other sites More sharing options...
Jsmith Posted August 26, 2018 Share Posted August 26, 2018 It's because you use quarts instead of liters. The vehicles are using metric measurements as standard. 5.1 US quarts is roughly 4.8 liters. How is that any better? As others have said, do not worry about the .1 quart. When you check your oil, you’ll never know the difference. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
