VespaGTS Posted May 7, 2018 Share Posted May 7, 2018 Hi Guys, I keep an eye on my COBB AP while driving and ever since I sealed up all the vaccuum leaks the numbers have improved a lot. Usually I see the DAM at 1.0 around town and even during spirited driving. I do travel over the Cascades mountains and this is where I see the DAM drop to .62 then it raises back up to .875 and finally 1.0 when the drive is going downhill and flattening out. Feedback Knock can be -8.0 but knock learn is never much below -3.0. So I guess the questions are as follows: Am I paranoid? Should DAM stay at 1.0 all the time. Can I expect 0.00 Knock and Knock Learn? This car at 122k on it and I want to be reasonable and not worried that she is about to blow up. Thanks in advance! Link to comment Share on other sites More sharing options...
relative4 Posted May 7, 2018 Share Posted May 7, 2018 Yes, DAM should stay at 1.0. That level of knock should be looked at, even at altitude. What are your A/F learning values in the A-C ranges at high and low elevations? It will be helpful to get an OBDLink or a VAG-COM/Tactrix cable so you can post a learning view with a timing grid. Are you running an OTS tune? Link to comment Share on other sites More sharing options...
VespaGTS Posted May 8, 2018 Author Share Posted May 8, 2018 I’ll stay out of boost until the cable shows up and I can do a real log. Link to comment Share on other sites More sharing options...
VespaGTS Posted May 10, 2018 Author Share Posted May 10, 2018 Yes, DAM should stay at 1.0. That level of knock should be looked at, even at altitude. What are your A/F learning values in the A-C ranges at high and low elevations? It will be helpful to get an OBDLink or a VAG-COM/Tactrix cable so you can post a learning view with a timing grid. Are you running an OTS tune? Here are my A/F learning values while I wait for the Tactrix cable. Sent from my iPad using Tapatalk Link to comment Share on other sites More sharing options...
relative4 Posted May 10, 2018 Share Posted May 10, 2018 Running lean in the C range suggests you may have a fuel delivery problem. How do the roughness counts look? Tried running a couple tanks of fuel system cleaner through it? Link to comment Share on other sites More sharing options...
VespaGTS Posted May 10, 2018 Author Share Posted May 10, 2018 Two tank fills with BG 44k. What else could it be? Link to comment Share on other sites More sharing options...
relative4 Posted May 10, 2018 Share Posted May 10, 2018 Pump, regulator, injectors, filter. See the vacay pics for the regulator test procedure. Roughness counts will help identify a bad injector. Link to comment Share on other sites More sharing options...
VespaGTS Posted May 10, 2018 Author Share Posted May 10, 2018 Roughness is at 0. Link to comment Share on other sites More sharing options...
relative4 Posted May 10, 2018 Share Posted May 10, 2018 All cylinders, all RPM ranges, under boost? Link to comment Share on other sites More sharing options...
VespaGTS Posted May 10, 2018 Author Share Posted May 10, 2018 I’ll have the cable shortly and see what happens. With no way to log this is an impossible task. I am running a Cobb OTS Map. Stage 1, 91 Octane. Link to comment Share on other sites More sharing options...
Outback2.5XT-05 Posted May 10, 2018 Share Posted May 10, 2018 Do a AP log with all of your favorite parameters. It's not the best log but it's literally designed for it. Link to comment Share on other sites More sharing options...
awesterner Posted May 10, 2018 Share Posted May 10, 2018 Here are my A/F learning values while I wait for the Tactrix cable. Sent from my iPad using Tapatalk Maybe you already know (or I'm late to the party:) but with the Taxtrix you will be logging a stock ECU configuration as it will not log a Cobb married Map. That being said, for trouble shooting; the Taxtrix is a good idea with the learning view as stated before:-) Link to comment Share on other sites More sharing options...
relative4 Posted May 10, 2018 Share Posted May 10, 2018 Maybe you already know (or I'm late to the party:) but with the Taxtrix you will be logging a stock ECU configuration as it will not log a Cobb married Map. That being said, for trouble shooting; the Taxtrix is a good idea with the learning view as stated before:-)Are you confusing logging and flashing? Link to comment Share on other sites More sharing options...
awesterner Posted May 11, 2018 Share Posted May 11, 2018 Are you confusing logging and flashing? No I'm talking about logging. Correct me if I'm wrong, but if he has a Cobb Map loaded then Tactrix won't recognize in RomRaider? At least that's my personal experience with it. After that I've always assumed that Cobb locks the ECU with their maps loaded. Maybe all along I just had setup issues with RR at that time and perhaps it would have worked Link to comment Share on other sites More sharing options...
VespaGTS Posted May 11, 2018 Author Share Posted May 11, 2018 Here is a log from COBB AP. 3rd gear pull starting at 40mph.datalog18.csv Link to comment Share on other sites More sharing options...
Gabo Posted May 11, 2018 Share Posted May 11, 2018 Vespa, my suggestion to you is to stop doing wide open throttle logs immediately. You've obviously made it this far and hopefully the log you just posted recorded the correct parameters for a tuner to make a determination. I understand that you are in the process of diagnosing the issue and there many factors to consider. It could be a fuel pressure issue, an injector issue, a vacuum leak issue, etc, etc. Going full throttle though is a risk you simply shouldn't be taking right now. I'm sorry for not being able to provide any other suggestion that could possibly lead to fixing the issue. Link to comment Share on other sites More sharing options...
VespaGTS Posted May 11, 2018 Author Share Posted May 11, 2018 I totally agree. I needed to see what a log looked like for the group. I have not been in boost much at all before this. Link to comment Share on other sites More sharing options...
VespaGTS Posted May 12, 2018 Author Share Posted May 12, 2018 So after cleaning the MAF again, tossing the K&N filter and installing a paper air filter my AF numbers dropped down a lot. AF Leanring 1a 1.20 AF Learning 1b 0.20 AF Learning 1c 3.30 AF Learning 1d 3.20 So that’s better at least. Link to comment Share on other sites More sharing options...
relative4 Posted May 12, 2018 Share Posted May 12, 2018 Nice! In case you're wondering, those numbers are to all intents and purposes perfect. How's the knocking? Link to comment Share on other sites More sharing options...
VespaGTS Posted May 12, 2018 Author Share Posted May 12, 2018 Knocking is basically at 0. There was a -1.5 at start of the pull that is gone now. I will post the numbers shortly. Roughness is at 0 across the board. These cars sure are sensitive. Link to comment Share on other sites More sharing options...
relative4 Posted May 12, 2018 Share Posted May 12, 2018 They sure are. But worth it. DAM staying at 1? I highly recommend getting an OBDLink and BtSsm. Link to comment Share on other sites More sharing options...
VespaGTS Posted May 12, 2018 Author Share Posted May 12, 2018 Yes DAM is staying at 1 the whole time. I don’t have an android phone but I am thinking it’s worth buying a Nexus 7 and the OBDlink Bluetooth and ditching the Cobb for a Protune. That way I can watch it all the time. Which OBDLink did you get I see three available. The Wi-Fi one for the Apple products is $200 so I don’t think I need that one. Unless it’s the best option? Link to comment Share on other sites More sharing options...
VespaGTS Posted May 12, 2018 Author Share Posted May 12, 2018 Can I use the Tactrix OP 2.0 for constant monitoring? It shows up on Monday. Link to comment Share on other sites More sharing options...
relative4 Posted May 12, 2018 Share Posted May 12, 2018 Yes DAM is staying at 1 the whole time. I don’t have an android phone but I am thinking it’s worth buying a Nexus 7 and the OBDlink Bluetooth and ditching the Cobb for a Protune. That way I can watch it all the time. Which OBDLink did you get I see three available. The Wi-Fi one for the Apple products is $200 so I don’t think I need that one. Unless it’s the best option?I got the MX, but I assume the LX would do fine. Any cheap Android will do the job. Link to comment Share on other sites More sharing options...
relative4 Posted May 12, 2018 Share Posted May 12, 2018 Can I use the Tactrix OP 2.0 for constant monitoring? It shows up on Monday.I think you need a computer in the car for that. You could mount it up all Fast-n-Furious like. Link to comment Share on other sites More sharing options...
