BGSEXXE Posted August 27, 2016 Share Posted August 27, 2016 Is there a list floating around that states what parts from other models that will fit the 4th gens? TIA!!! Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted August 27, 2016 I Donated Too Share Posted August 27, 2016 I'll start. cigarette lighter plug from all models fit. Link to comment Share on other sites More sharing options...
zangado1 Posted August 27, 2016 Share Posted August 27, 2016 Any factory Subaru wheels with a 5 x 100 bolt pattern will fit too.. Link to comment Share on other sites More sharing options...
JmP6889928 Posted August 27, 2016 Share Posted August 27, 2016 H7 bulbs Link to comment Share on other sites More sharing options...
WRX USA Posted August 27, 2016 Share Posted August 27, 2016 The e-brake cover is shared with 08+ Impreza, also the front sway bar for the LGT are shared with 08-11 WRX (and NA shares the same as NA Impreza). Link to comment Share on other sites More sharing options...
Mike07LGT Posted August 28, 2016 Share Posted August 28, 2016 Top mount intercooler is the same for 08-14 wrx and 05-09 legacy gt 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
Scruffy Posted August 28, 2016 Share Posted August 28, 2016 The ipod integration units from the 08-09 STI H621SFG500 and 09 Forester H621SFG501 both worked perfectly with my 08 2.5i (manual climate) Link to comment Share on other sites More sharing options...
covertrussian Posted August 30, 2016 Share Posted August 30, 2016 08+ WRX Front lower control arm bushings, Up Pipes, 08+ WRX Downpipes. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
honduhunter Posted August 30, 2016 Share Posted August 30, 2016 08+ WRX Front lower control arm bushings, Up Pipes, 08+ WRX Downpipes. Thats only for the manual trans though right? Link to comment Share on other sites More sharing options...
utc_pyro Posted August 30, 2016 Share Posted August 30, 2016 Thats only for the manual trans though right? The '08 WRX came with a 4eat option and they had the "GT" for a year or two after that as well. FXT fitment ones work as well, they were all 4EAT. Link to comment Share on other sites More sharing options...
Scruffy Posted August 31, 2016 Share Posted August 31, 2016 Another one I just thought of, Auto-dimming mirrors, mines off an 05 Forester, completely different part numbers but fit perfectly.. plug and play. $30 vs 120 As long as the mount and plug matches it will work Link to comment Share on other sites More sharing options...
BGSEXXE Posted August 31, 2016 Author Share Posted August 31, 2016 Thanks a lot fellas!! What about intakes? Will the 08 and up WRX aftermarket intakes fit as well? Link to comment Share on other sites More sharing options...
utc_pyro Posted August 31, 2016 Share Posted August 31, 2016 What about intakes? Will the 08 and up WRX aftermarket intakes fit as well? It uses a different MAF sensor, so not directly. You could in theory convert the wiring and re-tune so it'd work, but that can get $$$. There is also some slight geometry differences in the finder well so intakes that stick down there (AEM, Mishimoto) may have issues. Simular to '08+ sedan exaust. Really close, but to get it to fully work would cost more than it's worth in most cases. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted August 31, 2016 Share Posted August 31, 2016 Does anyone know if the 08+ Sti lower suspension braces would fit? Like these: http://turninconcepts.com/brace-lower-control-arm.html Link to comment Share on other sites More sharing options...
BGSEXXE Posted August 31, 2016 Author Share Posted August 31, 2016 It uses a different MAF sensor, so not directly. You could in theory convert the wiring and re-tune so it'd work, but that can get $$$. There is also some slight geometry differences in the finder well so intakes that stick down there (AEM, Mishimoto) may have issues. Simular to '08+ sedan exaust. Really close, but to get it to fully work would cost more than it's worth in most cases. Appreciate the info. Thank you!! Link to comment Share on other sites More sharing options...
