MaStaMooN Posted February 10, 2015 Share Posted February 10, 2015 Has anybody had any issues with this setup? Going over like speed bumps or something like that makes a pretty good clunky sound. As far as I can tell everything is tight, springs are situated correctly. I don't remember it making these sounds when I installed them last spring. Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
digger47 Posted February 10, 2015 Share Posted February 10, 2015 Check your endlinks Link to comment Share on other sites More sharing options...
apexi Posted February 10, 2015 Share Posted February 10, 2015 If you've had this setup installed for awhile and this just started, I agree with end links. Even if they're not broken, one of the nuts could be loose. Link to comment Share on other sites More sharing options...
MaStaMooN Posted February 11, 2015 Author Share Posted February 11, 2015 I'll check them out! Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
iNVAR Posted February 12, 2015 Share Posted February 12, 2015 Koni inserts installed incorrectly. Strut housings were cut too short possibly? Link to comment Share on other sites More sharing options...
MaStaMooN Posted February 12, 2015 Author Share Posted February 12, 2015 Don't think so, the nubs went in the body and I verified that the strut bottomed out. Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
iNVAR Posted February 12, 2015 Share Posted February 12, 2015 How far into the body? They CAN come loose if they're not in far enough. Link to comment Share on other sites More sharing options...
MaStaMooN Posted February 12, 2015 Author Share Posted February 12, 2015 I don't remember exactly, but it wasn't just barely iirc. And I used the pipe cutter as far up as possible method, I believe they were slightly longer than specified. I'll have my shop look around when I bring it in for a leaky oil pan. Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
iNVAR Posted February 12, 2015 Share Posted February 12, 2015 Reach in behind the wheels and grab the strut housing and give it a good wiggle. Also wiggle the inserts themselves. If anything moves, you've found the problem. Otherwise, maybe your LCA bushings are shot. Link to comment Share on other sites More sharing options...
