Metal2You Posted May 8, 2010 Share Posted May 8, 2010 Does anybody know the part numbers or any good sources to get new knuckles for an '06 GT? Lets just say we had a little trouble removing the stock ball joints Link to comment Share on other sites More sharing options...
ebpda9 Posted May 8, 2010 Share Posted May 8, 2010 ouch. i threw away the boxes, but they were 118/piece at my dealership. Do yourself a favor and get the bearings too, as most likely they are gonna get damaged when taken out. Link to comment Share on other sites More sharing options...
Underdog Posted May 9, 2010 Share Posted May 9, 2010 I can help you with that. I'll dig up a part number in the AM. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Metal2You Posted May 26, 2010 Author Share Posted May 26, 2010 Are the GT and Spec B knuckles the same? If they're different I probably got the wrong one... Link to comment Share on other sites More sharing options...
FredBeans Posted May 26, 2010 Share Posted May 26, 2010 28313AG00A and 28313AG01A are the original part number for '05-'06 GT & Spec.B. For the '07-'09 GTs and Spec.Bs, the original number was *02A and *03A. The older part numbers (*00A and *01A) for the '05-'06 GT and Spec.B were replaced with the new numbers at some point. Both *02A and *03A were revised yet again to *02B and *03B. This is the latest part number for all '05-'09 Legacy GT and Spec.B knuckles. Which ones did you get? Link to comment Share on other sites More sharing options...
Metal2You Posted May 26, 2010 Author Share Posted May 26, 2010 Looks like I'm good to go, I got *02B and *03B. Thanks for the detailed info there. Anybody know the relevant torque specs for the hub assembly bolts, ball joint pinch bolts, castle nuts, etc? Link to comment Share on other sites More sharing options...
FredBeans Posted May 26, 2010 Share Posted May 26, 2010 Anybody? *edit* Posted all three diagrams in your new thread: http://legacygt.com/forums/showthread.php/steering-knuckle-torque-specs-138423.html?t=138423 Link to comment Share on other sites More sharing options...
Metal2You Posted May 26, 2010 Author Share Posted May 26, 2010 YOU. ROCK. Part of the reason I enjoy giving you my business, just placed an order this morning actually. That and PA to CT is one day shipping at standard rates. I don't see the torque specs for bolting the hub assembly or tie rod end into the knuckle on there though. Link to comment Share on other sites More sharing options...
Metal2You Posted May 26, 2010 Author Share Posted May 26, 2010 Got the rest of the specs from the thread in basic maintenance section. You're the man. Link to comment Share on other sites More sharing options...
FredBeans Posted May 26, 2010 Share Posted May 26, 2010 Did you check the other thread? Posts #3 and #4 have those two specs. Here they are anyways: Hub-to-knuckle bolts: 47.9 ft*lbs Tie-rod catle nut: 19.9 ft*lbs *edit* No problem man... let me know if you need anything else. Link to comment Share on other sites More sharing options...
