carguyco Posted February 9, 2010 Share Posted February 9, 2010 I have the windshield wiper defrost option on my 07 LGT...When you push the button should it light up? Mine doesn't...I have no idea if it is working...anyone? Thanks in advance. Link to comment Share on other sites More sharing options...
joeblow Posted February 9, 2010 Share Posted February 9, 2010 Went out and checked and there is a little orange-ish light that indicates that the defroster is on. I never really paid attention to see if there was a light. Its an interesting feature, but I still question the utility of it. I don't notice any difference whether its on or off vs. the regular windshield defrost. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
Max Capacity Posted February 9, 2010 Share Posted February 9, 2010 IMO, yes it should. Mine does in my 05GT Read the owners manual. 05's only run for 15 minutes unless you have the dealer override it. There is also something about outside air temp too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
GULLABLE0NE Posted February 9, 2010 Share Posted February 9, 2010 the button lights up on my 2008 LGT but i'm skeptical that it actually works Link to comment Share on other sites More sharing options...
SpecBGuy Posted February 9, 2010 Share Posted February 9, 2010 so no one actually tried the wiper snow defrost? i would but doesnt snow in Los Angeles =( Link to comment Share on other sites More sharing options...
joeblow Posted February 9, 2010 Share Posted February 9, 2010 I use it from time to time because its there, but I can't tell any real difference between that and the regular full windshield defrost. I mean the windshield defrosts from the bottom up anyway, so I haven't noticed anything special. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
rao Posted February 9, 2010 Share Posted February 9, 2010 There is a light on the button and it is pretty useful - it won't melt a foot if ice, but it works faster than the HVAC defrost at least until the coolant gets up to operating temperature. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
carguyco Posted February 9, 2010 Author Share Posted February 9, 2010 My light on my button never comes on....I read the manual.... I will check the fuse... Link to comment Share on other sites More sharing options...
EquinnoxX Posted February 9, 2010 Share Posted February 9, 2010 I've had my wipers still ice up in some pretty crazy storms with the defrost on but for the most part they're ok. Link to comment Share on other sites More sharing options...
Vimy101 Posted February 9, 2010 Share Posted February 9, 2010 That function is a neat feature to melt accumulating snow and help keep the wiper blade more pliable. It isn't a "defrost" button per se. Link to comment Share on other sites More sharing options...
CapnJack Posted February 9, 2010 Share Posted February 9, 2010 It also depends on the type of wipers you have. If you have the bridge/truss style, the defroster doesn't work very well. If you have the Bosch Icon style, the defroster will save the day on snowy days. I notice on mine, sometimes I have to hold the button in for a second and then it will come on, almost like it's waiting for the holding contactor to pull in. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted February 9, 2010 Share Posted February 9, 2010 Read the owners manual. 05's only run for 15 minutes unless you have the dealer override it. There is also something about outside air temp too. I think it won't come on if it's warmer than 41 degrees. Link to comment Share on other sites More sharing options...
vr4Legacy Posted February 9, 2010 Share Posted February 9, 2010 I questioned the utility of it when I bought my car (I was in NC at the time) the sales lady said she uses it more for defogging the windows.. I have noticed it will actually work quite well for that while the engine is warming up.... I have also noticed if you start the car and let it run for a minute or two with a little (<1") of snow on the window you can see def melting snow where the heater is... I wanted to see if it really did anything... low and behold it did. But to answer your main question, in my '08 yes it does light up. Link to comment Share on other sites More sharing options...
carguyco Posted February 9, 2010 Author Share Posted February 9, 2010 I think it won't come on if it's warmer than 41 degrees. No problem there....I think Iwill hold the button down a little longer and see what happens...otherwise I will begin to trace the problem. Link to comment Share on other sites More sharing options...
CDN 2.5i Posted February 9, 2010 Share Posted February 9, 2010 On Canadian cars and any others that have the 'cold weather package', the same button will control the heat for the sideview mirrors as well. You'll see the element on the windshield where the wipers rest if you have the heated windshield - looks like rear window defrost elements but thicker. Link to comment Share on other sites More sharing options...
tjbev21 Posted February 10, 2010 Share Posted February 10, 2010 ^ i believe the USDMs also have the heated side mirror function Link to comment Share on other sites More sharing options...
joeblow Posted February 10, 2010 Share Posted February 10, 2010 Side mirrors are connected to the rear defroster on the USDM, its not a separate switch like the wiper one. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
Vimy101 Posted February 10, 2010 Share Posted February 10, 2010 I questioned the utility of it when I bought my car (I was in NC at the time) the sales lady said she uses it more for defogging the windows.. I have noticed it will actually work quite well for that while the engine is warming up.... The sales lady is clueless. The function of the windshield elements is to melt snow and improve wiper performance not to defrost the windows. Using the function without snow to absorb the heat risks cracking the glass. Plenty of posts on that. Link to comment Share on other sites More sharing options...
mwiener2 Posted February 10, 2010 Share Posted February 10, 2010 I use mine alot. Makes a noticeable difference. You can feel that the area with the elements does get quite warm when it's working. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
carguyco Posted February 10, 2010 Author Share Posted February 10, 2010 According to my owner's manual the fuse for the wiper element is also the same fuse as the moon roof...moon roof works, deicer doesn't....it appears I have a different problem... Time to hit google..... Link to comment Share on other sites More sharing options...
pillboy Posted February 10, 2010 Share Posted February 10, 2010 There is a light on the button and it is pretty useful - it won't melt a foot if ice, but it works faster than the HVAC defrost at least until the coolant gets up to operating temperature. My god, the light on that button must get hot... It is still ugly. Link to comment Share on other sites More sharing options...
thx247 Posted February 10, 2010 Share Posted February 10, 2010 Is this different between OB's and Legacys? In the OB the windshield and side mirrors are on that switch, the rear window defrost is on its own switch. Side mirrors are connected to the rear defroster on the USDM, its not a separate switch like the wiper one. Link to comment Share on other sites More sharing options...
joeblow Posted February 10, 2010 Share Posted February 10, 2010 I don't know, I've never driven an OB to look at the gauge cluster. I just know on my LGT, the side mirrors have the rear defrost symbol on them (the square vs. cone-ish of the windshield) It's cool; I'm with the band Link to comment Share on other sites More sharing options...
Mr. Sinister Posted February 10, 2010 Share Posted February 10, 2010 My god, the light on that button must get hot... Link to comment Share on other sites More sharing options...
BrooklynBoy Posted February 10, 2010 Share Posted February 10, 2010 My god, the light on that button must get hot... :) (what's it got?......like a laser beam or sumptin' ?) :) Do it right the first time.........or don't bother doing it at all. Link to comment Share on other sites More sharing options...
