Fabsx Posted June 20, 2018 Share Posted June 20, 2018 Hello all! Currently looking for a replacement manual transmission for my moms 2010 2.5i Legacy. I was wondering if the 13/14 year legacy will fit? Not sure if much changed, but it seemed to be more available for those years then 2010-2012. Any info input would be great appreciated. Thanks Link to comment Share on other sites More sharing options...
GTEASER Posted June 20, 2018 Share Posted June 20, 2018 Should be exactly the same. The only difference might be very small ratio differences. Go to Cars101 to verify the ratios. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
dgoodhue Posted June 20, 2018 Share Posted June 20, 2018 Should be exactly the same. The only difference might be very small ratio differences. Go to Cars101 to verify the ratios. Car101 incorrectly lists the drive ratio as 4.44:1 when it is 4.11:1. I remember after buying my 2012 2.5i that 2013 had a different final drive ratio than mine and I assumed that was correct for years. When I was doing research last year on ExtraMT and Subaru recommended gear oil. I opened up 2014 Service Manual and while I was looking at the gear oil and I noticed the final drive ratio was the same as the 2010-2012. Link to comment Share on other sites More sharing options...
dgoodhue Posted June 20, 2018 Share Posted June 20, 2018 When I was looking at 6MT assembly part numbers, it seem like every model year had a different part number. The 2010-12 GT all did, as did the 2013 & 2014 2.5i (I didn't look up the 2010-2012 2.5i 6MT) I can't imagine them being all that different. I suspect they just got continuous improvements. Link to comment Share on other sites More sharing options...
Fabsx Posted June 20, 2018 Author Share Posted June 20, 2018 I looked at the part number for the complete transmission from a 2010 to a 2013. Both different. So idk, should I bite the bullet? Link to comment Share on other sites More sharing options...
FLlegacy Posted June 20, 2018 Share Posted June 20, 2018 For piece of mind you could always swap in the rear diff as well from the same car. Link to comment Share on other sites More sharing options...
Fabsx Posted June 20, 2018 Author Share Posted June 20, 2018 I overlooked at Subaru parts for the rear differential gear set. They state it fits years 10-14. The only concern is will the transmission have the same mounting points? Bell housing, trans mount, etc. Link to comment Share on other sites More sharing options...
FLlegacy Posted June 20, 2018 Share Posted June 20, 2018 Afaik all the mounting points are the same. Sent from my SAMSUNG-SM-G920A using Tapatalk Link to comment Share on other sites More sharing options...
Fabsx Posted June 20, 2018 Author Share Posted June 20, 2018 Didn’t the 13+ legacy get the FB motors? Therefore, are the transmission from a EJ to FB swap able, or vice versa? I just want to be 100% sure before going forward in purchasing the trans and not working. Link to comment Share on other sites More sharing options...
FLlegacy Posted June 20, 2018 Share Posted June 20, 2018 I don't think anything is different other than the engine having a timing chain and a few other upgrades. I would be shocked if Subaru had changed the bolt pattern since it has been the same since the mid 90s. Link to comment Share on other sites More sharing options...
Fabsx Posted July 23, 2018 Author Share Posted July 23, 2018 Just figured I’d rest this thread and help anyone else in the future. 2013/2014 Legacy transmission will in fact work on a 2010-2012 Legacy. Everything bolted straight up with absolutely no issues. Fb and Ej series do have same bell housings bolts and pattern. Cheers!! Link to comment Share on other sites More sharing options...
