luken Posted July 2, 2018 Share Posted July 2, 2018 i have installed some LEDs as high beams in my 012 legacy 2.5i prem. From what i've read no one is too big a fan of LEDs! but that aside i am using them to look nice as my DRLs and they wont blind anyone at night since they are just the high beams. So all this would be nice if they turned on, however they do not light up at all, but the indicator on my dash does when i put them on. They are supposed to be plug and play but obviously thats not the case. I used Auxito 9005 72w bulbs and im sure i plugged in the headlights correctly because the other lights work fine. Also might be useful to know i switched to all black housing headlights at the same time. (taking the bumper off was fun) Anyone with knowledge of this out there, help would be appreciated! Link to comment Share on other sites More sharing options...
Scooby Fan Posted July 2, 2018 Share Posted July 2, 2018 Your DRL's are the high beams at a much reduced power so they only come one at a dimmer light. As I understand LED high beams they will not light up with the reduced power in the DRL circuit. Do the new LED's light up okay when you put the headlights "On" and flip them to high beam? If not you have a problem other than the DRL situation. Link to comment Share on other sites More sharing options...
coco26 Posted July 2, 2018 Share Posted July 2, 2018 LEDs are polarity-sensitive... If they don't light up at all, check to make sure the connectors at the bulb can't be flipped the other way. Link to comment Share on other sites More sharing options...
Perscitus Posted July 3, 2018 Share Posted July 3, 2018 There are a few high-beam replacement flavors on the market now that are polarity-agnostic and have no issue running as DRLs at the lower output. VLEDs, Alibaba, Aliexpress, Rakuten vendors, etc. Link to comment Share on other sites More sharing options...
luken Posted July 3, 2018 Author Share Posted July 3, 2018 Your DRL's are the high beams at a much reduced power so they only come one at a dimmer light. As I understand LED high beams they will not light up with the reduced power in the DRL circuit. Do the new LED's light up okay when you put the headlights "On" and flip them to high beam? If not you have a problem other than the DRL situation. they wont light at all, not with manually switching to them either. thank you all for the reply's! Link to comment Share on other sites More sharing options...
Scooby Fan Posted July 3, 2018 Share Posted July 3, 2018 As above......check the polarity of the connections. Link to comment Share on other sites More sharing options...
LegitLegacy Posted July 11, 2018 Share Posted July 11, 2018 Agree with above, flip the connection and it will work. I am running them in my high beams. I disconnected the DRL plug because I do not like the look. However keep in mind that if you keep your DRL on with them, they will be very bright even during the day. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted July 16, 2018 Share Posted July 16, 2018 LEDs are your DRL is not really a good option as they will be almost as bright as when they are on. Most LED headlights are designed to run on 6-24V. This would, IMHO be a much better option https://smile.amazon.com/Philips-12824WLVWAC1-DayLight-Powered-Daytime/dp/B005DX6BKW/ref=sr_1_2?ie=UTF8&qid=1531744515&sr=8-2&keywords=phillips+drl+led+lights Link to comment Share on other sites More sharing options...
DrD123 Posted July 21, 2018 Share Posted July 21, 2018 You wouldn't think making a retrofit LED bulb that worked properly as a DRL would be that hard... most reviews show the high beams either flicker or work on something too close to full brightness. Those Philips lights look interesting, but are a bit large - it looks like they had a smaller version (the DayLight 4 instead of the Daylight 8) but I haven't found them for sale anywhere Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted July 21, 2018 Share Posted July 21, 2018 when you stick those on the bumper in the opening, they will look just fine. Link to comment Share on other sites More sharing options...
fedaykin Posted August 21, 2018 Share Posted August 21, 2018 You could disable the DRL (They are called daytime running lights, so they should be off when you turn your park/low beam on i.e. DRL go off at night). I have a MY10 with no factory DRL, threw some Diode Dynamics HB3/9005 bulbs in: Pretty good replacements, I recommend them. That's OE HID low beam, colours don't match so I gave them to my brother, he has MY15 WRX with OE LED low beam so they match. Link to comment Share on other sites More sharing options...
NORULZleggy Posted August 21, 2018 Share Posted August 21, 2018 Diode Dynamic makes a 9005 LED Fog light bulb that I used as my DRL lights in 2013 Legacy 2.5i, I had a set of 4 year old VLED bulbs but one burned out after a few weeks. Plus they sat in a box for 2 years and might have got knocked around. Get Diode Dynamic or VLED 9005 LEDS if you want them for DRL. People always ask if my car is new cause they see the crisp look of the LEDs from Diode Dynamic. Link to comment Share on other sites More sharing options...
DrD123 Posted August 22, 2018 Share Posted August 22, 2018 Do they run at reduced intensity as a DRL, or do you pretty much have your high beams on all the time? The diode dynamics website doesn't say Link to comment Share on other sites More sharing options...
NORULZleggy Posted August 22, 2018 Share Posted August 22, 2018 Do they run at reduced intensity as a DRL, or do you pretty much have your high beams on all the time? The diode dynamics website doesn't say they are not High beam bright, because they are labeled a fog light. Also if you need you Hi's then this might not be for you. But my 13 Legacy looks great, and I could drive down the highway with them on at night cause the LED are so bright. DD makes the HP48 version which is nice. If you turn on you Hi's then you get the full intensity, to me it looks very good. Link to comment Share on other sites More sharing options...
