JDM EJ25 swap and mini build in Canadian 2011 LGT
Hey guys
Last week I had my engine go on my 2011 LGT. Wasn't beating on it at the time nor have I beaten on it really since I've owned the car. Could have been a previous owner issue. I've always kept the car well maintained.
The car is currently stage 2.
I have purchased a JDM EJ255 engine that came out of a 2012 Legacy GT from Japan. Maybe the first JDM swap for this year?
Below is what I have coming for the car and some services being done for my "mini build". She should be a lot of fun when it's done!
All work being done at NV Auto in Hamilton Ontario, Canada. Check them out on FB and Instagram. They have some really cool builds. Their shop car is a 2jz BRZ they competitively drift with!
Engine:
- 2012 LGT JDM engine (low km)
- 2008+ STi exhuast cams (+1mm lift)
- 2008+ STi valve springs
- 2008+ STi valve seals
- 2008+ STi valve retainers
- Depot Top Mount Intercooler
- ARP head studs
- Heads replaned
- Valve clearance
- Valve cleaning
- Valve grind/lap
- New OEM oil pick up
- 2010 STi oil pump (11mm)
- Intake manifold gaskets
- Exhaust manifold gaskets
- Turbo to manifold gasket
- Turbo to downpipe gasket
- Camshaft seals
- Head Gaskets
- Water pump gasket
- New OEM water pump
- New OEM thermostat
- Coolant crossover pipe O-rings
- Oil Pickup & O-ring
- New OEM oil cooler
- Gates timing belt kit
- Turbosmart Dual Port by pass valve
Exhaust:
- 3" Invidia catless downpipe
- 2008' STi exhaust
- High flow cat with metal core
- 2.5" custom Y pipe
- 2.5" Magnaflow Y collector
- 2.5"* Vibrant Ultra Quiet resonator
- 2.5 inch highflow mufflers
Fuel:
- DW200 (255 lph) fuel pump
- Stock injectors (ID 1000's sitting in my garage to be installed)
Transmission/drivetrain:
- Stage 2 Comp clutch
- Resurfaced flywheel
- Royal Purple fluids (transmission and diff)
Suspension:
- Gecko G-racing 32 way adjustable coilovers with camber plates
- Urethane bushing kit
- Wheel spacers
- Whiteline 22mm Adjustable sway bar
Brakes
- 04+ STi Brembo front calipers
- STi Stoptech slotted rotors
- Stoptech pads
Gauges:
- AEM digital boost gauge
- AEM UEGO Wideband
Tune:
- COBB Pro tune at Definitive Tuning .
I'll keep this thread updated as I progress!
Car and new engine:
af150158c7a959a5e0acdc847e52f463.jpg0cccad6bfb535bd82730377fe1a37420.jpga19a0289d3e7da2fff9c8234c25aed6f.jpgd29832822ff80e105092bf899ff2ccb9.jpg614c25e6b03a2ad957ddc2f621d8f7cd.jpg417f294c7e6d2fda8602f00a58d663c9.jpg
  • Replies 188
  • Created
  • Last Reply
Dam you gteaser and your quickness.. and he's in Canada.... If Gteaser doesn't grab the turbo, I'd be interested.
Sounds good. 99% keeping the turbo though. Next time I'm around MTL we should get together for a beer and some pictures! In the 3 years owning my FG LGT I've only seen 3 others!
I wouldn't be surprised if our production numbers in Canada are the same or less than the US at 2000.
Sent from my SM-G930W8 using Tapatalk
Sounds good, also after your bnr upgrade is done, i'd be interested in your old one. :p
Let the fun begin! Enjoy. But be wise on the saying - "pay to play".
Agreed. I'm overly focused on upgrading all the parts that keep my setup reliable. New oil pick up, new Sti oil pump (debating on getting it blue printed), fuel and cooling.
I want to make good reliable power.
I can't afford to drop another massive amount of money to rebuild my daily again. We are expecting our first in a few weeks! Baby boy :)
In a couple years I'll invest in a forged bottom end. The financial hit won't be nearly as bad now that my top end is refreshed/mini built lol
Clearly you are meant to stack the manifolds for triple protection. That's how it works. I would know. My father was an EJ.
As for the rest of this build, Dis gon b gud :munch:
Ahhhhh now it makes sense!!!! Haha. So in that case, I'm short a gasket!!
Thanks buddy! It's been fun so far and all I'm doing is collecting parts! She goes in Nov 6. The wait is killing me.
Since I would assume you are using the TGVs you actually do have an extra but the intake gaskets are O-ring type gaskets since the intake is plastic.
https://www.buyautoparts.com/data/all_images/MS19516-MH.jpg
