jrae2424 Posted September 4, 2020 Share Posted September 4, 2020 (edited) I have an 05 legacy gt with an sti ra shortblock. I'm getting 300whp with 307tq on a mustang dyno, 5eat transmission. Looking to upgrade from the vf52 to the 1.5 xtr and am was wondering what top mount I need to make it work and anything else. Thanks Edited September 4, 2020 by jrae2424 Link to comment Share on other sites More sharing options...
DaveWaters Posted September 4, 2020 Share Posted September 4, 2020 For the intercooler. A Grimmspeed tmic would be your best bet with the hose below. https://www.grimmspeed.com/top-mount-intercooler-turbo-outlet-hose-subaru-08-14-wrx-05-09-legacy-gt/?gclid=EAIaIQobChMIgYbhx8DP6wIVE9bACh0v7Q4uEAQYAiABEgKwd_D_BwE Link to comment Share on other sites More sharing options...
jrae2424 Posted September 4, 2020 Author Share Posted September 4, 2020 For the intercooler. A Grimmspeed tmic would be your best bet with the hose below. https://www.grimmspeed.com/top-mount-intercooler-turbo-outlet-hose-subaru-08-14-wrx-05-09-legacy-gt/?gclid=EAIaIQobChMIgYbhx8DP6wIVE9bACh0v7Q4uEAQYAiABEgKwd_D_BwE I see a complete kit for $970, would this process west work? https://www.rallysportdirect.com/part/intercoolers/prw-pwtmic00b-process-west-top-mount-intercooler-black Link to comment Share on other sites More sharing options...
jrae2424 Posted September 4, 2020 Author Share Posted September 4, 2020 (edited) I see a complete kit for $970, would this process west work? And I'm still confused as to why exactly the AVO top mount I have won't work with the 1.5 xtr? Also, someone recommened going with the blouch 380xt which would illiminate the need to upgrade the top mount? I'm trying to get to 340-350 whp with the 5eat. I have 850cc injectors, exhaust, fuel pump, intake, headers, boost controller, downpipe, upipe. so there shouldn't much more to do other than a proper turbo. https://www.rallysportdirect.com/part/intercoolers/prw-pwtmic00b-process-west-top-mount-intercooler-black Edited September 4, 2020 by jrae2424 Link to comment Share on other sites More sharing options...
Max Capacity Posted September 4, 2020 Share Posted September 4, 2020 (edited) That Process West is for a STI. You need the GS tmic for a Legacy GT. It is the best fitting and easiest to install and work with. Both my cars have one. https://www.grimmspeed.com/categories/make/subaru/legacy-legacy-gt/intercooler/ Here's the stock set up on my Spec B. The vf52 in the wagon is the same. For a 1.5xtr turbo you would need a different hose from the turbo. Edited September 9, 2020 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jrae2424 Posted September 4, 2020 Author Share Posted September 4, 2020 That Process West is for a STI. You need the GS tmic for a Legacy GT. It is the best fitting and easiest to install and work with. Both my cars have one. https://www.grimmspeed.com/categories/make/subaru/legacy-legacy-gt/intercooler/ Sweet. I'll think I'll put the order in today. Am that pretty cool to see that you still have the wagon after 8 years, how many miles at this point, and how is it running? I would love to come down and check them out sometime, or if you have a link to some pics, send them my way. Link to comment Share on other sites More sharing options...
DaveWaters Posted September 4, 2020 Share Posted September 4, 2020 Don’t forget you’ll need that $85 hose I listed above as well because the GS TMIC comes with the flange mount and hose for stock turbo, which actually is why the AVO won’t work with the xtr. The compressor outlet on the xtr is STI style not flange style like the WRX/LGT. Also the GS LGT TMIC will come with the proper hood splitter which Process West no longer makes from what I understand. Although I believe boxkita on this forum may still have some custom made splitters available. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 4, 2020 Share Posted September 4, 2020 Sweet. I'll think I'll put the order in today. Am that pretty cool to see that you still have the wagon after 8 years, how many miles at this point, and how is it running? I would love to come down and check them out sometime, or if you have a link to some pics, send them my way. I've had the wagon since new June 28 2004, currently has 294,800 miles. The Spec B I bought Mar 2011, it has 93,000 miles Both have custom tunes from tuningalliance@gmail.com they run flawlessly. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
boxkita Posted September 4, 2020 Share Posted September 4, 2020 Don’t forget you’ll need that $85 hose I listed above as well because the GS TMIC comes with the flange mount and hose for stock turbo, which actually is why the AVO won’t work with the xtr. The compressor outlet on the xtr is STI style not flange style like the WRX/LGT. Also the GS LGT TMIC will come with the proper hood splitter which Process West no longer makes from what I understand. Although I believe boxkita on this forum may still have some custom made splitters available. i have a couple left. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Pleides Posted September 8, 2020 Share Posted September 8, 2020 FWIW, I have a Perrin TMIC and I like it. It doesn't require modifications to the hood scoop like the Grimmspeed unit does. It's quite bulky, but it's well-made and handles my VF46 just fine. Link to comment Share on other sites More sharing options...
boxkita Posted September 9, 2020 Share Posted September 9, 2020 The PW tmic required an upgraded under hood scoop. This ensured the intercooler all the received airflow possible. The sealing gasket ensured an airtight fit. Probably need to put my extra one up for sale. Not going to use it. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
DaveWaters Posted September 9, 2020 Share Posted September 9, 2020 FWIW, I have a Perrin TMIC and I like it. It doesn't require modifications to the hood scoop like the Grimmspeed unit does. It's quite bulky, but it's well-made and handles my VF46 just fine. The 1.5xtr has a hose type compressor outlet unlike the VF46’s two bolt flange outlet. The Grimmspeed and Process west can accommodate this. Link to comment Share on other sites More sharing options...
m sprank Posted September 9, 2020 Share Posted September 9, 2020 The Dom 1.5XTR will be CHOKED by a TMIC. WASTE of money to use that turbo with a TMIC. It was designed for a FMIC and if you speak to Blouch they will confirm my findings. Not to mention the transmission strain on the 5EAT. Need to do some work there too. Link to comment Share on other sites More sharing options...
shralp Posted September 9, 2020 Share Posted September 9, 2020 The Dom 1.5XTR will be CHOKED by a TMIC. WASTE of money to use that turbo with a TMIC. It was designed for a FMIC and if you speak to Blouch they will confirm my findings. Not to mention the transmission strain on the 5EAT. Need to do some work there too. Msprank can you elaborate on this comment a bit? I ask because not only do I know a few forum members locally that are running a 1.5xtr with good success and making good power (on Grimmspeed topmounts), but my next upgrade for the track car was going to be this turbo or maybe even a 2.5xtr. I’d prefer to stay top mount thru this process and this is the first time anyone has ever mentioned that these Turbos are not suited well to TMIC’s Link to comment Share on other sites More sharing options...
boxkita Posted September 9, 2020 Share Posted September 9, 2020 Shralp you seem like a good candidate for the "next" owner of the race wagon, which comes with a monstrous Perrin fmic. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
shralp Posted September 9, 2020 Share Posted September 9, 2020 Shralp you seem like a good candidate for the "next" owner of the race wagon, which comes with a monstrous Perrin fmic. All it takes is money! Link to comment Share on other sites More sharing options...
Spoolin06XT Posted September 9, 2020 Share Posted September 9, 2020 Don’t forget you’ll need that $85 hose I listed above as well because the GS TMIC comes with the flange mount and hose for stock turbo, which actually is why the AVO won’t work with the xtr. The compressor outlet on the xtr is STI style not flange style like the WRX/LGT. Also the GS LGT TMIC will come with the proper hood splitter which Process West no longer makes from what I understand. Although I believe boxkita on this forum may still have some custom made splitters available. @DaveWaters.....could he use this hose with the VF52 or the hose that comes with the Intercooler kit will work fine? Link to comment Share on other sites More sharing options...
DaveWaters Posted September 9, 2020 Share Posted September 9, 2020 The hose that comes with the intercooler works with the VF52,46,40. It comes with a flange and Oring to bolt to the turbo. The outlet it creates is on top but you’d need the additional hose for the side outlet on an 1.5 xtr Link to comment Share on other sites More sharing options...
m sprank Posted September 9, 2020 Share Posted September 9, 2020 Msprank can you elaborate on this comment a bit? I ask because not only do I know a few forum members locally that are running a 1.5xtr with good success and making good power (on Grimmspeed topmounts), but my next upgrade for the track car was going to be this turbo or maybe even a 2.5xtr. I’d prefer to stay top mount thru this process and this is the first time anyone has ever mentioned that these Turbos are not suited well to TMIC’s Good success meaning they have no clue how much they left on the table. Why spend good money on a good turbo to not use its potential? The DOM 1.5XTR was my favorite street turbo. Capable of making 20+ psi by the mid 3000rpm's and with PROPER supporting mods can make well over 400whp on a stock block (Mustang AWD dyno). Many 6 to 5 downshifts left 4 tires spinning at speed. So much fun its dangerous. The required cooling for the compressed intake charge can not be properly accomplished by a TMIC. Not a PW, not a GS, certainly not an AVO or Perrin or any of the knock offs. The turbo NEEDS a FMIC to operate as designed. Call Blouch and ask if the DOM 1.5XTR is recommended with a TMIC and they will tell you "No, it is designed to be used with a FMIC". Same for all the XTR turbos. All GREAT turbos imho. The fast boost hit creates a lot of low end torque, which destroys the 5EAT without proper modifications. Link to comment Share on other sites More sharing options...
shralp Posted September 10, 2020 Share Posted September 10, 2020 Good success meaning they have no clue how much they left on the table. Why spend good money on a good turbo to not use its potential? The DOM 1.5XTR was my favorite street turbo. Capable of making 20+ psi by the mid 3000rpm's and with PROPER supporting mods can make well over 400whp on a stock block (Mustang AWD dyno). Many 6 to 5 downshifts left 4 tires spinning at speed. So much fun its dangerous. The required cooling for the compressed intake charge can not be properly accomplished by a TMIC. Not a PW, not a GS, certainly not an AVO or Perrin or any of the knock offs. The turbo NEEDS a FMIC to operate as designed. Call Blouch and ask if the DOM 1.5XTR is recommended with a TMIC and they will tell you "No, it is designed to be used with a FMIC". Same for all the XTR turbos. All GREAT turbos imho. The fast boost hit creates a lot of low end torque, which destroys the 5EAT without proper modifications. Given the constraints your talking about with a TMIC, (Grimmspeed for instance), what would be your pick for a turbo that maximizes the potential of the set up for a track car, (assuming proper fueling, and other necessary mods are in place)? Asking for a friend Link to comment Share on other sites More sharing options...
m sprank Posted September 12, 2020 Share Posted September 12, 2020 What type of track? HPDE, SCCA, Auto-X, drag, etc? For cone killing and small course you want fast spool and power/torque to come on fast. For a longer road course you can use larger/later spooling turbos. For the drags... As you want to stay with a TMIC, I would not go larger than an 18g. With an 05 5EAT I would look into a shift kit as well. Link to comment Share on other sites More sharing options...
shralp Posted September 12, 2020 Share Posted September 12, 2020 (edited) All HPDE road race track, no sanctioned racing other than Time Trials once in awhile. Dang, you feel 20G is even too big for a large TMIC? Currently running a custom EVO 16G built by JMP. Tranny is a STI 6 speed. Edited September 12, 2020 by shralp Link to comment Share on other sites More sharing options...
Marvick08GT Posted September 12, 2020 Share Posted September 12, 2020 I will be running the dom 1.5xtr 10cm on E85 with a grimmspeed tmic. I still have some odds and ends to button up, will be dyno tuned 10/15 and 10/16. My old GT ran the BCP x500+ and x500 both on 21psi on the GS tmic with 93 octane Link to comment Share on other sites More sharing options...
shralp Posted September 12, 2020 Share Posted September 12, 2020 I will be running the dom 1.5xtr 10cm on E85 with a grimmspeed tmic. I still have some odds and ends to button up, will be dyno tuned 10/15 and 10/16. My old GT ran the BCP x500+ and x500 both on 21psi on the GS tmic with 93 octane Any chance you'll be doing a 93 pump gas tune as well? Love to hear what kind of numbers you put down Link to comment Share on other sites More sharing options...
Marvick08GT Posted September 12, 2020 Share Posted September 12, 2020 (edited) Sure will, it will be tuned on 93 and then E85. I will be running a flex fuel setup. Will keep it posted! Will be tuned by the same shop and tuner (Hill @ Agile Automotive) that did the x500 and x500+. So it will be a direct comparison for those turbos as well Edited September 13, 2020 by Marvick08GT Link to comment Share on other sites More sharing options...
Register a new accountSign in
