subaruzi Posted December 17, 2018 Share Posted December 17, 2018 See video. The ignition/start sounds harsh to me. All the whining sounds like something needing to be fixed. Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
relative4 Posted December 17, 2018 Share Posted December 17, 2018 Cold out, yes? The O-ring sealing the power steering pump to the reservoir suction hose is old and hard. Part number 34439FG000, or you can maybe get one from a hardware store with an unusually good selection. Link to comment Share on other sites More sharing options...
apexi Posted December 18, 2018 Share Posted December 18, 2018 Yeah, I'd replace the o-ring which may have shrunk due to age and colder weather, allowing air to get into the PS system, causing noise. You'll probably lose a little fluid when replacing the o-ring, so I'd have extra ps fluid (Subaru atf-hp) on hand. Also not a bad idea to replace the ps fluid. You could use a turkey baster or something to suck the old fluid out of the reservoir, and pour new fluid in, but it's not too hard to do a more thorough flush. The total capacity of the ps system isn't much, service manual says .2qt for the oil tank, .7qt for the whole system. This is what I did the first time around, when it was my first time ever replacing ps fluid. https://legacygt.com/forums/showpost.php?p=5259262&postcount=84 I unbolt the reservoir, unhook the hose towards the back of the car, and put it into an empty cup/bottle whatever. I no longer use the camera since I know how quickly the fluid gets sucked in by the system, at that time I was worried and had no idea. The car will really suck down the fluid when the steering wheel is all the way locked to the right or left, I hear it's not good to hold the wheel that way for too long anyway. Here's a picture of where the o-ring lives https://legacygt.com/forums/showpost.php?p=5091736&postcount=115 Link to comment Share on other sites More sharing options...
subaruzi Posted December 18, 2018 Author Share Posted December 18, 2018 You guys/gals are awesome! I'm in New Orleans so it's cold by our standards. I'll give it a shot this weekend if I can find the o-ring locally. Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
