Th3Franz Posted May 15, 2015 Share Posted May 15, 2015 Well, it's time. I'm working with a fabricator to adapt his existing rotated kit to fit an EFR twin scroll 7163. I'm pretty excited to see how fast I can get the new setup to spool and where it ends up for top end power. Some details.. 321SS twin scroll header 321SS twin scroll up-pipe EFR7163 IWG T4 twin scroll 0.80 A/R 304SS v-band downpipe with flex 3 in. MAF intake for rotated turbo Turbosmart dual port IWG actuator I'm keeping with the ported STI intake manifold with stock orientation for now. I still have my LGT intake manifold if I decide to flip it later on. I will be reusing my AVO FMIC and ID1000s with DW300 hardwired. I plan to run 93 octane for daily driving but may do 100 or 110 octane tune as well for some fun on track. If Cobb comes out with flex fuel support for the AccessPort I may go with ID1300's and go that route. I will be starting with a MAF tune and then working on a speed density tune. I already have the 4 BAR MAP sensor and relocated IAT sensor. Any suggestions for install or small parts to use with the EFR? I'm planning to get AN fittings for the oil drain and coolant ports. I will be blocking off their BOV and using only my Tial Q. I may use the EFR BCS if I can determine what connector it uses in advance and make an adapter harness to the stock connector. You can find my built motor thread but it's a built bottom end with GSC S1 head work and mild porting. The headwork should pair nicely with the power band of the 7163. Current setup is a DOM1.5XT-R 10cm with Grimmspeed manifolds and up-pipe. Making some notes for myself for fitting sizes and mating parts. -4AN oil feed fitting 3/8NPT oil drain / M8x1.25 holes Water ports: M14x1.5 Update 9/20/15: See post #26 for pics. Still cleaning up the install a little bit but it's functional. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Rester5350 Posted May 15, 2015 Share Posted May 15, 2015 Sounds like a fun set up! Do you have pics of the header/up pipe? Are you running stock sized valves? Link to comment Share on other sites More sharing options...
sjxbrd Posted May 15, 2015 Share Posted May 15, 2015 I just got a BW EFR6258 working in the stock location without the FR kit (fabricated up pipe and down pipe). Let me know if you need a list of oil and coolant fittings to make EFR turbo's work on our cars. Link to comment Share on other sites More sharing options...
Th3Franz Posted May 15, 2015 Author Share Posted May 15, 2015 I have some sample pics of the header up-pipe I'll upload. Fabricator is modifying for IWG and EFR Stock sized valves. Larger valves are pointless. sjxbrd, Yeah if you have a list of the oil and coolant fittings, that would be awesome! -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Nightmaresmk Posted May 19, 2015 Share Posted May 19, 2015 Should be one fun ride. can't wait to see it completed. Link to comment Share on other sites More sharing options...
Streetlegal Posted May 19, 2015 Share Posted May 19, 2015 Where in WI are you? Might want to check out your old kit Is it rotated or stock location? Want to follow this too because it sounds awesome Link to comment Share on other sites More sharing options...
rapture Posted May 19, 2015 Share Posted May 19, 2015 Wow. ... Link to comment Share on other sites More sharing options...
heiche Posted May 19, 2015 Share Posted May 19, 2015 Looks fierce! Will the hood close? BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
Max Capacity Posted May 20, 2015 Share Posted May 20, 2015 3/8 oil drain, Don't they normally run something like 5/8 or 3/4, at least 1/2" ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Th3Franz Posted May 20, 2015 Author Share Posted May 20, 2015 It's 3/8 npt but instead I'm getting the 10an adapter so it has a larger diameter Without an npt fitting. http://www.treadstoneperformance.com/product.phtml?p=67987&prodname=EFR+%26+Garrett+GT+Oil+Drain+Return+Flange%2C+-10AN -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
dahoseman Posted May 24, 2015 Share Posted May 24, 2015 I have some sample pics of the header up-pipe I'll upload. Fabricator is modifying for IWG and EFR Stock sized valves. Larger valves are pointless. sjxbrd, Yeah if you have a list of the oil and coolant fittings, that would be awesome! That is sexy Link to comment Share on other sites More sharing options...
Th3Franz Posted June 8, 2015 Author Share Posted June 8, 2015 Half naked turbo -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Th3Franz Posted July 29, 2015 Author Share Posted July 29, 2015 exhaust pipes arrived. hoping to install this weekend -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
quick4dr Posted July 29, 2015 Share Posted July 29, 2015 is that the weld porn work of Tigwerks? Link to comment Share on other sites More sharing options...
Th3Franz Posted July 30, 2015 Author Share Posted July 30, 2015 is that the weld porn work of Tigwerks? Indeed it is -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
fahr_side Posted July 30, 2015 Share Posted July 30, 2015 Suggest you ditch the TiAL and use the built-in BPV instead. This is much of the reason boost recovery is near instantaneous on this turbo. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
Th3Franz Posted July 31, 2015 Author Share Posted July 31, 2015 I'll have to experiment with that. I don't have a good way to plug the flange where the Tial goes on atm. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
quick4dr Posted July 31, 2015 Share Posted July 31, 2015 they sell v band caps for tial flanges Link to comment Share on other sites More sharing options...
Th3Franz Posted July 31, 2015 Author Share Posted July 31, 2015 do you know where I can find a cap? -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
BDII Posted July 31, 2015 Share Posted July 31, 2015 Subbed. Th3Franz always delivers. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
GipsySpec.B Posted July 31, 2015 Share Posted July 31, 2015 Subscribed because twinscrollllll Link to comment Share on other sites More sharing options...
Th3Franz Posted August 3, 2015 Author Share Posted August 3, 2015 I found a turbo smart 50mm flange blank plate. Hope it fits. Gonna give the efr bpv a try first. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Th3Franz Posted September 17, 2015 Author Share Posted September 17, 2015 The turbosmart 50mm flange blank plate doesn't work. The Tial has a lip on the outside which I forgot about. So, I am using the EFR BPV and the Tial BOV is still installed with no pressure reference connected to it. I do not hear it opening up or anything and briefly ran 14 PSI tonight. The EFR BPV is so quiet and the car runs nicely with it. I like it. We just ironed out some fitment issues with the kit, so I am happy with how it fits now. I am going to re-run the vacuum lines for using both ports of my IWG actuator. Then, open loop tuning starts and I'll share some logs. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
quick4dr Posted September 17, 2015 Share Posted September 17, 2015 results should be fun, regardless of numbers, that thing is going to be a neck snapper. Link to comment Share on other sites More sharing options...
BDII Posted September 17, 2015 Share Posted September 17, 2015 Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
