tobin Posted February 23, 2019 Share Posted February 23, 2019 Greetings, I recently inherited a 2006 Outback wagon, less than 65k, new head gaskets/timing belt/the whole 9 yards. When I got the car, it had a P0420 code (catalyst system efficiency below threshold bank 1). I replaced both O2 sensors, changed plugs (all looked very good), wires, coil pack, cleaned throttle body and top end. It ran much better after all of this. I cleared the code and went about my business. Fast forward a couple of months, and the P0420 code is back. The car still runs fine. Are there any usual suspects I should be looking for? http://www.canyonero.com/files/1550939656.jpg Link to comment Share on other sites More sharing options...
relative4 Posted February 23, 2019 Share Posted February 23, 2019 Occam's Razor says bad cat. A cheap infrared thermometer will allow you to compare the cat's upstream & downstream temps. Link to comment Share on other sites More sharing options...
whitetiger Posted February 23, 2019 Share Posted February 23, 2019 Yep cat or sensors. Since the sensors were done, it can only be the cat. Link to comment Share on other sites More sharing options...
bigfatdaddy Posted February 23, 2019 Share Posted February 23, 2019 Vacuum leaks are also a cause for the code. Check all your vacuum fittings and hoses (there aren't many) including the PCV. Link to comment Share on other sites More sharing options...
tobin Posted February 23, 2019 Author Share Posted February 23, 2019 Thanks folks! I'll triple check for loose fittings, then start cat shopping. Link to comment Share on other sites More sharing options...
ArmyVetMP Posted February 23, 2019 Share Posted February 23, 2019 I would HIGHLY Recommend a OEM Cat. I replaced my CAT with an aftermarket one a couple years back. Within a year that CAT went bad and cost me over $2k to replace a 2nd time, since it required a nearly all new exhaust system. Our Subaru's, especially those with the PZEV Motors do not like Aftermarket! Link to comment Share on other sites More sharing options...
bigBADbenny Posted February 23, 2019 Share Posted February 23, 2019 There’s also the $5 fix. https://www.google.com.au/search?q=subaru+p0240+fix&ie=UTF-8&oe=UTF-8&hl=en-gb&client=safari If you’re turbo & tuned its common to delete the code, in turn providing the opportunity to ecu log a wbo2 via the rear o2 sensor harness. Link to comment Share on other sites More sharing options...
relative4 Posted February 23, 2019 Share Posted February 23, 2019 Do NOT go cat shopping until you've verified the cat is bad. That's an expensive part to pointlessly swap. Never heard of a vacuum leak causing a P0420. Link to comment Share on other sites More sharing options...
apexi Posted February 23, 2019 Share Posted February 23, 2019 Looks like a CT plate in the background, a pzev state. It's worth talking to the dealer to see if it's covered under the 15 year/150k pzev emissions warranty. They'll probably have to run the VIN to check. 2nd to last page, not a lot of detail though. http://sltg.subarunet.com/static/pdf/Quick_Reference_Material.pdf Link to comment Share on other sites More sharing options...
tobin Posted February 23, 2019 Author Share Posted February 23, 2019 Looks like a CT plate in the background, a pzev state. It's worth talking to the dealer to see if it's covered under the 15 year/150k pzev emissions warranty. They'll probably have to run the VIN to check. 2nd to last page, not a lot of detail though. http://sltg.subarunet.com/static/pdf/Quick_Reference_Material.pdf Oooh...awesome idea. Definitely worth a shot. Thank you. There’s also the $5 fix. https://www.google.com.au/search?q=subaru+p0240+fix&ie=UTF-8&oe=UTF-8&hl=en-gb&client=safari If you’re turbo & tuned its common to delete the code, in turn providing the opportunity to ecu log a wbo2 via the rear o2 sensor harness. Another great tip...thanks very much. This seems like a great way to test cat failure before I replace it like a law-abiding citizen Link to comment Share on other sites More sharing options...
ehsnils Posted February 24, 2019 Share Posted February 24, 2019 When at it - have the injectors checked/cleaned and make sure that they all have the same fuel flow. Mismatched injectors eats cats. Link to comment Share on other sites More sharing options...
dgoodhue Posted February 25, 2019 Share Posted February 25, 2019 Do NOT go cat shopping until you've verified the cat is bad. That's an expensive part to pointlessly swap. Never heard of a vacuum leak causing a P0420. I have had an small upstream exhaust leak (exhaust flange) cause a P0420 code on another vehicle. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 25, 2019 Share Posted February 25, 2019 Make sure the wires are in good shape. That wire harness is close to a lot of items. In a hot area. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
relative4 Posted February 26, 2019 Share Posted February 26, 2019 I have had an small upstream exhaust leak (exhaust flange) cause a P0420 code on another vehicle.Absolutely. Vacuum leak, not so much. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted February 26, 2019 Share Posted February 26, 2019 Check fuel trims and make sure they are +/- 10. A vacuum leak can cause the car to falsely set a 420. Link to comment Share on other sites More sharing options...
tobin Posted March 6, 2019 Author Share Posted March 6, 2019 I brought it to a mechanic who diagnosed it as a bad cat. They quoted around 800 installed to replace the front cat assembly. Is that about right? Link to comment Share on other sites More sharing options...
whitetiger Posted March 6, 2019 Share Posted March 6, 2019 well, you could buy an aftermarket OE replacement cat for alot less money, but quality with them varies so you might have to replace it again in a couple years. in the end, its up to you. Link to comment Share on other sites More sharing options...
apexi Posted March 6, 2019 Share Posted March 6, 2019 I wonder if they were going to use an OEM subaru cat, or aftermarket for 800? If it's OEM, that sounds like a fair price to me. Link to comment Share on other sites More sharing options...
bigfatdaddy Posted March 11, 2019 Share Posted March 11, 2019 I was getting P0420 on a 07 Legacy last month until I found a PCV line that was not properly seated. P0420s have now stopped. Read about O2 sensors and you will find that they can be affected by vacuum leaks. http://www.ffwdm.com/test/vacuum-leak.jpg Link to comment Share on other sites More sharing options...
tobin Posted March 12, 2019 Author Share Posted March 12, 2019 I was getting P0420 on a 07 Legacy last month until I found a PCV line that was not properly seated. P0420s have now stopped. Read about O2 sensors and you will find that they can be affected by vacuum leaks. Thank you, I'll check the vacuum hoses. I was screwing around in that area recently when replacing stuff. I put a spacer on the O2 sensor for now and will see how long that lasts. Link to comment Share on other sites More sharing options...
