Carmania24 Posted August 17, 2019 Share Posted August 17, 2019 Hi all, I accidentally clicked something in my car when my phone dropped and now the radio display's the number 1 and whenever I click radio or press 1, 2, 3, etc to my radio present's nothing happens and it just stays on the same radio station. Can someone help me please? Thank you!!!!! Link to comment Share on other sites More sharing options...
Shogun506 Posted August 17, 2019 Share Posted August 17, 2019 I'm sure there's a way to bring it back to normal. Post a pic. If you REALLY can't figure it out, worst case scenario you can always disconnect your battery, turn the key to on to drain the residual and then reconnect it. Should reset everything. Link to comment Share on other sites More sharing options...
ttnio Posted August 18, 2019 Share Posted August 18, 2019 disconnect the main power harness of the headunit, the reconnect. Link to comment Share on other sites More sharing options...
Carmania24 Posted August 18, 2019 Author Share Posted August 18, 2019 I'm sure there's a way to bring it back to normal. Post a pic. If you REALLY can't figure it out, worst case scenario you can always disconnect your battery, turn the key to on to drain the residual and then reconnect it. Should reset everything. disconnect the main power harness of the headunit, the reconnect. Thank you both, it worked. Phew I thought I broke it. Link to comment Share on other sites More sharing options...
