coloradoG Posted July 27, 2013 Share Posted July 27, 2013 Also read that a poor ground could short the radio Link to comment Share on other sites More sharing options...
Max Capacity Posted July 27, 2013 Share Posted July 27, 2013 You may want to make sure all the grounds are clean, including the battery. this may help. http://people.csail.mit.edu/ilh/vacation/ 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
coloradoG Posted August 16, 2013 Author Share Posted August 16, 2013 grounds cleaned, car was driving perfect (except spedometer still not responsive) until I hit a pot-hole and the check engine light came on. also immediately the car started shifting funny P0700 P0720 - Output shaft speed sensor circuit Took into another ASE certified highly rated subaru shop for diagnoses, they said something about they think my front passenger bearing could cause circuit/connection issues with vibrations, and also that "the speed censor in front passenger was the one that spoke directly with cluster" I called every dealership in the state and several subi mechanic shops and no one could verify that information for me... However, when I went to the get the wheel bearing from dealership the parts guy showed me a transmission wiring harness which had all new wires and 4 sensors, he said he was almost willing to bet his job that that's what it was. appreciate the help, I'll update when solved.. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 17, 2013 Share Posted August 17, 2013 http://people.csail.mit.edu/ilh/vacation/ You should find some useful info in these. In the back of the books are pictures of how thing work. Also check out the the very first forum here, at the top is a sticky, oppsed forces link. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
