subie.snob Posted February 16, 2013 Share Posted February 16, 2013 For a couple days now I have been hearing a grinding in my front passenger side wheel when I take a sharp left. I know I have a small tear in my passenger sde cv boot, but I always thought that when a cv joint goes it is a clunking, not grinding sound. I also thought if it was my wheel bearing it wouldn't only be grinding when I turn. I was thinking I might have a stuck caliper because it is inconsistent grinding but then that doesn't really make sense to me either with the whole turning thing. Unfortunately, I'm visiting family in CT now and don't have a way to really check anything. I was hoping you guys might have some input for what I should look for when I get home next week. Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted February 16, 2013 Share Posted February 16, 2013 Its a wheel bearing, its grinding when you turn because you are "loading" that side of the vehicle while turning. But these things are known to need front calipers too.. At least this past year I know of 3 mass members that needed at least one caliper.. N.E sucks, your in ME I know you know what Im saying Link to comment Share on other sites More sharing options...
subie.snob Posted February 16, 2013 Author Share Posted February 16, 2013 Wouldn't I be loading the side I'm turning into? If I'm turning left doesn't the car lean that way and put more downward force on the drivers side, not passenger? Or is it the force from the car trying to prevent the lean? Sorry I sometimes over think things. At least it will be an easy fix.... Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted February 16, 2013 Share Posted February 16, 2013 when you turn left you load the right side, when you turn right you load the left side, body roll goes away from the turn not into the turn.. check caliper also before just throwing a bearing in there, just cause its a known issue in shitty climates/road conditions Link to comment Share on other sites More sharing options...
subie.snob Posted February 16, 2013 Author Share Posted February 16, 2013 Thanks for the quick responses! Link to comment Share on other sites More sharing options...
TheBlackPearl Posted February 16, 2013 Share Posted February 16, 2013 "For every action, there is an equal and opposite reaction"Â Self proclaimed PNW Craiglist find of the day Champion, April 2014. Link to comment Share on other sites More sharing options...
subie.snob Posted February 16, 2013 Author Share Posted February 16, 2013 Thanks Newton. :-p Link to comment Share on other sites More sharing options...
ehsnils Posted February 16, 2013 Share Posted February 16, 2013 Grinding can also be the wear indicator on the pads. Link to comment Share on other sites More sharing options...
subie.snob Posted February 16, 2013 Author Share Posted February 16, 2013 Doesn't that usually grind while braking though? Link to comment Share on other sites More sharing options...
ehsnils Posted February 17, 2013 Share Posted February 17, 2013 Usually yes, but it's worth checking anyway. Sometimes the grinding noise is only audible at certain pressure and when the pressure gets harder it changes to a frequency beyond human ears. Just so you don't waste money on something that isn't a problem and is easy to check. Link to comment Share on other sites More sharing options...
Fitz Posted February 18, 2013 Share Posted February 18, 2013 I would agree with a wheel barring, and just last week my right front caliper sized at 112k lmao... so it made a griding noise and when I washed the car, I noticed the right rotor smoked when water hit it vs the left... just another quick test if u have been light on the breaks be for the wash as I had just went 1.1miles to the store and back... lmao Link to comment Share on other sites More sharing options...
subie.snob Posted February 18, 2013 Author Share Posted February 18, 2013 Washed my car this morning... It's no longer grinding. Possible some dirt/salt was causing the caliper to hang up? Link to comment Share on other sites More sharing options...
Van Pelt Posted February 18, 2013 Share Posted February 18, 2013 Maybe a piece of road grime between rotor and backing plate. Happened to me once in winter. Although I did replace 2 right front well bearings in my 09 Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted February 18, 2013 Share Posted February 18, 2013 Some buildup in pads probably, but calipers slides can start to seize and free up, then get stiff again. I would definitely look into soon. Link to comment Share on other sites More sharing options...
chato Posted February 18, 2013 Share Posted February 18, 2013 I've had my car get road grit caught between the brakes and the heatshield. Makes a horrific sound that amplifies when turning. Best way I found to undo it is to reverse and it usually pops out. Link to comment Share on other sites More sharing options...
