samuel082799 Posted May 24, 2020 Share Posted May 24, 2020 I have my Oem headers off right now because I am putting a new engine in. While having the headers off I noticed that the insides are very dirty and I want to clean them so nothing goes into my freshly rebuilt turbo. It seems like soot or carbon build-up, but whatever it is it cant be good. the car burned a lot of oil so that probably has something to do with it. what is the best way to clean them out? I have heard of just soaking them in dish soap and water, but maybe one of yall has some better ideas. Link to comment Share on other sites More sharing options...
Dalee1104 Posted May 24, 2020 Share Posted May 24, 2020 If you really wanted to brake and parts cleaner is pretty much some of the strongest stuff to spray in there. Pretty much dissolves most things. If the brake clean doesnt kill it then I doubt it would come off and affect the turbo too much Link to comment Share on other sites More sharing options...
Max Capacity Posted May 24, 2020 Share Posted May 24, 2020 Acetone might do a good job, but make sure you're outside using it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
samuel082799 Posted May 25, 2020 Author Share Posted May 25, 2020 It looked like welding slag, but I'm guessing it is from the casting, could be bits of melted rings IDK. I put a wire cup on my drill and ran it through and it seemed to take most of it off. then I shot it with brake cleaner to get out the rest of the carbon build-up. Now I got another question, about cleaning my intercooler. It has oil in it because my turbo was really blown and went through a quart of oil a week, and I don't drive much. What is the best way to clean out an intercooler? I've watched people poor gas in there until it comes out clean, but I don't know how to dispose of gas. Is there a better way to clean intercoolers, will brake clean work too? Link to comment Share on other sites More sharing options...
Max Capacity Posted May 25, 2020 Share Posted May 25, 2020 Dawn dishwashing liquid would be my choice. They use it to remove oil from animals caught in a oil spill. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
lilredwagon Posted May 30, 2020 Share Posted May 30, 2020 For intercoolers, you can usually empty a can of brake clean in it and swish it around and then dump it out. Keep doing that until it comes out relatively clean. Link to comment Share on other sites More sharing options...
