HDTurbo Posted June 6, 2022 Share Posted June 6, 2022 Oil change on spec b. LiquiMoly 5/40 as Rotella was unavailable. 10+ years on Infamous stage 3 tune. 72k mi. Enjoying the $93 octane… Thanks Shamar. Link to comment Share on other sites More sharing options...
SubOperator Posted June 6, 2022 Share Posted June 6, 2022 No Rotella T6 around here either, might have to look at LiquiMoly again, I believe Napa carries it. 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 248K 2007 B9 Tribeca Limited DGM - 258K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 6, 2022 Share Posted June 6, 2022 Can't believe rotella T6 is still not being sold anywhere. Found some 5w40 synthetic valvoline at Walmart. Hopefully it should be fine. Link to comment Share on other sites More sharing options...
NORULZleggy Posted June 6, 2022 Share Posted June 6, 2022 Can't believe rotella T6 is still not being sold anywhere. Found some 5w40 synthetic valvoline at Walmart. Hopefully it should be fine. Amsoil has 5w-40 all day errr day :lol:check it out. Link to comment Share on other sites More sharing options...
NORULZleggy Posted June 6, 2022 Share Posted June 6, 2022 Got the car ready to go to the shop to get External setup installed, Modified VF52 turbo to pump out some POWA, New protune, see what's the deal with my weird smell that is trans fluid , getting and inspection, once that car is all done, clean it up and put my gold wheels back on, and I am ready for summer. Or ready for it to sit in the garage :lol: shooting for the 350 mark for sure. I will post up what I get. Stay tuned. Oh have fresh Amsoil Full spas 5w-40 and filter, and a fresh full tank of 93 cause IM RICH, not really I am crying haah. Link to comment Share on other sites More sharing options...
kzr750r1 Posted June 6, 2022 Share Posted June 6, 2022 Went to Chevron Delo 400 XSP 5w40 after not finding T6 in town. May stay with it. Link to comment Share on other sites More sharing options...
whitexc Posted June 6, 2022 Share Posted June 6, 2022 I found some STP synthetic diesel oil I will be running for the next few changes. Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
seanyb505 Posted June 6, 2022 Share Posted June 6, 2022 So my engine has always had a very faint light knocking noise at idle ever since day one. I'm in a drive through and I just heard it stop. Kinda reminds me of that one saying, it's bad when something stops leaking because that's means there's no fluid left. May need a new short block by end of day. Link to comment Share on other sites More sharing options...
awfulwaffle Posted June 6, 2022 Share Posted June 6, 2022 New wheels and tires finally set. Much different look than the snowflakes I had on before, which are now my winter wheels since one is slightly bent and I can't get a replacement. Look is growing on me, and the Michelin PS4S is a great tire both wet and dry. I'll make an addition to the wheel fitment thread with specs once I can find it. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 6, 2022 Share Posted June 6, 2022 (edited) Amsoil has 5w-40 all day errr day :lol:check it out. As some may know, both my cars have been on this oil since 2013. I do 7-8000 mile oil changes. Amsoil may cost a bit more up front, but the benefits and longer intervals, make it a good deal. I went to longer intervals based on the results from Blackstone labs. The wagon's ej257 has over 150,000 miles on it and has none of the Subaru engine noises. My driving range has changed since retirement, but both cars are driven for longer drivers when they are driven. Just saying. I think NORULZleggy can take care of you with this. Mike at AZPinstalls.com got me into this oil and I have been a preferred member since then. Edited June 6, 2022 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rhino6303 Posted June 6, 2022 Share Posted June 6, 2022 Got the car ready to go to the shop to get External setup installed, Modified VF52 turbo to pump out some POWA, New protune, see what's the deal with my weird smell that is trans fluid [emoji38], getting and inspection, once that car is all done, clean it up and put my gold wheels back on, and I am ready for summer. Or ready for it to sit in the garage [emoji38][emoji38] shooting for the 350 mark for sure. I will post up what I get. Stay tuned. Oh have fresh Amsoil Full spas 5w-40 and filter, and a fresh full tank of 93 cause IM RICH, not really I am crying haah.I'm still eagerly awaiting for the VW bearing number... Also, I still just use whatever 5w40 or 0w40 I can get my hands on (usually Castrol or Mobil 1). I change at 4k miles and use an oem filter so I don't worry about it. Link to comment Share on other sites More sharing options...
seanyb505 Posted June 6, 2022 Share Posted June 6, 2022 New wheels and tires finally set. Much different look than the snowflakes I had on before, which are now my winter wheels since one is slightly bent and I can't get a replacement. Look is growing on me, and the Michelin PS4S is a great tire both wet and dry. I'll make an addition to the wheel fitment thread with specs once I can find it. 245/40/17? PS4S is an amazing tire. Even the AS4S is pretty good. Link to comment Share on other sites More sharing options...
NORULZleggy Posted June 6, 2022 Share Posted June 6, 2022 I'm still eagerly awaiting for the VW bearing number... Also, I still just use whatever 5w40 or 0w40 I can get my hands on (usually Castrol or Mobil 1). I change at 4k miles and use an oem filter so I don't worry about it. I have it on my list to ask Link to comment Share on other sites More sharing options...
lagwagon Posted June 6, 2022 Share Posted June 6, 2022 On Saturday both cars got new wiper blades and the 2005 got a new PS pump o-ring (the upper supply line from the reservoir), which seems to have stopped the leak, and also had the nut on one wiper arm tightened. Ordered three more PCV hoses this morning to be replaced when the left valve cover gasket and injectors get done. I think all the larger PCV hoses will then be new and only smaller vacuum lines are original. Link to comment Share on other sites More sharing options...
Febreze Mee Posted June 7, 2022 Share Posted June 7, 2022 Waffle! Those wheels look amazing. It was between these or the RPF1s for my first set, but I decided a few months ago these would be my second set for dedicated HPDE. The RPF1s are currently wrapped in MPS4S, and I am also happy with the tire. Wheel threads: https://legacygt.com/forums/showthread.php/bl-bp-legacy-gt-meaty-tire-thread-223705.html https://legacygt.com/forums/showthread.php/official-legacy-wheel-fitment-thread-182819.html https://legacygt.com/forums/showthread.php/official-aftermarket-wheels-thread-11208.html https://legacygt.com/forums/showthread.php/faq-offsets-sizes-rims-and-tires-gt-xenonk-version-vol-262472.html MILKRUN - Click Here Link to comment Share on other sites More sharing options...
awfulwaffle Posted June 7, 2022 Share Posted June 7, 2022 245/40/17? PS4S is an amazing tire. Even the AS4S is pretty good. Yep, 245/40/17. Blown away by the wet traction in particular, compared to the other summers I've run. Link to comment Share on other sites More sharing options...
awfulwaffle Posted June 7, 2022 Share Posted June 7, 2022 Waffle! Those wheels look amazing. It was between these or the RPF1s for my first set, but I decided a few months ago these would be my second set for dedicated HPDE. The RPF1s are currently wrapped in MPS4S, and I am also happy with the tire. Wheel threads: https://legacygt.com/forums/showthread.php/bl-bp-legacy-gt-meaty-tire-thread-223705.html https://legacygt.com/forums/showthread.php/official-legacy-wheel-fitment-thread-182819.html https://legacygt.com/forums/showthread.php/official-aftermarket-wheels-thread-11208.html https://legacygt.com/forums/showthread.php/faq-offsets-sizes-rims-and-tires-gt-xenonk-version-vol-262472.html Thanks! I'll add some info to those threads after grabbing some close-up photos. Link to comment Share on other sites More sharing options...
whitexc Posted June 7, 2022 Share Posted June 7, 2022 (edited) I have it on my list to ask [emoji38]Following...as the money pit at my house now needs front wheel bearings done at 79k. What is everyone using? Thinking of going the Napa route as they say lifetime. It will have never seize after the first one so shouldn't be a horrible job, not that you want to do it often. Sent from my SM-G996U using Tapatalk Edited June 7, 2022 by whitexc Link to comment Share on other sites More sharing options...
shralp Posted June 7, 2022 Share Posted June 7, 2022 Following...as the money pit at my house now needs front wheel bearings done at 79k. What is everyone using? Thinking of going the Napa route as they say lifetime. It will have never seize after the first one so shouldn't be a horrible job, not that you want to do it often. Sent from my SM-G996U using Tapatalk I know, they are more expensive for sure, but I've never had great luck with aftermarket wheel bearings so I only use OEM. For me, its an opportunity cost as they "can" be a bitch to replace. The lifetime warranty is nice but I guess I'd rather go one and done for a long time. Link to comment Share on other sites More sharing options...
Marvick08GT Posted June 7, 2022 Share Posted June 7, 2022 Subaru or Napa, the good ones. They will outlast the engine more than likely.. xD Link to comment Share on other sites More sharing options...
kzr750r1 Posted June 7, 2022 Share Posted June 7, 2022 Installed some Timken on the OBXT last year. They were bought thru Rock Auto years ago. Since I was replacing both from CV figured it was time. Sure enough... Was a good move. Still on stock wheel set so probably not pushed hard over their life. Seems most go thru them faster on larger wheels with more offset. Link to comment Share on other sites More sharing options...
whitexc Posted June 8, 2022 Share Posted June 8, 2022 (edited) Oil change with STP synthetic diesel 5w40, Mazda filter and two Napa front wheel bearings today. The car is much quiter. My trusty shop did the work. I like to golf and glamp rather than spend my little bit of free time wrenching these days. It costs me but such is life. Sent from my SM-G996U using Tapatalk Edited June 8, 2022 by whitexc Link to comment Share on other sites More sharing options...
Kojak Posted June 8, 2022 Share Posted June 8, 2022 Got my replacement mirror in today from a WTB post. Community ftw. Bearings. Thanks fellas. Added to the growing front end tighten up to-do list. I used to laugh at all the posts from dads saying their Leggy had taken a backseat to other members of the fam. Jokes on me now. I get it. But my boy is nearly two and is just getting into cars. Pretty fun to see. Link to comment Share on other sites More sharing options...
NORULZleggy Posted June 8, 2022 Share Posted June 8, 2022 Following...as the money pit at my house now needs front wheel bearings done at 79k. What is everyone using? Thinking of going the Napa route as they say lifetime. It will have never seize after the first one so shouldn't be a horrible job, not that you want to do it often. Sent from my SM-G996U using Tapatalk Ok so they are FAG wheel bearing hubs is what I have on my car, they are made in Germany from what the shop was saying. they have tons more lube than what most brands have and they last like crazy. Hey and who doesn't like more lube ahahaah Now I am waiting on the car to be completed. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 8, 2022 Share Posted June 8, 2022 (edited) Ok so they are FAG wheel bearing hubs is what I have on my car, they are made in Germany from what the shop was saying. they have tons more lube than what most brands have and they last like crazy. Hey and who doesn't like more lube ahahaah Now I am waiting on the car to be completed. I gather you mean these ? https://www.summitracing.com/search/brand/fag-bearings/part-type/wheel-bearing-and-hub-assemblies/year/2005/make/subaru/model/legacy Seems p/n 101908 and 101909 are the numbers we need. Notice the "ship date" Here's the fronts, https://www.summitracing.com/parts/fwb-101908 I copied the info from Summits site and asked google to find more "shopping" options on Google. https://www.google.com/search?q=FAG+wheel+bearing+hubs&rlz=1C1OKWM_enUS906US906&sourceid=chrome&ie=UTF-8 So, here, you'll see the Summit site, pop's up first. https://www.google.com/search?q=FAG+wheel+bearing+hubs+101908&sa=X&rlz=1C1OKWM_enUS906US906&biw=1280&bih=881&tbm=shop&sxsrf=ALiCzsZnkJH-CPgx7dJcenPrcusQNnV3KQ%3A1654704850570&ei=0sqgYsWmIv2bptQPgLqfuAU&ved=0ahUKEwjF1832n574AhX9jYkEHQDdB1cQ4dUDCAY&oq=FAG+wheel+bearing+hubs+101908&gs_lcp=Cgtwcm9kdWN0cy1jYxAMOgsIrgEQygMQsAMQJ0oECEEYAVDBDFjdHmDeTmgBcAB4AIABjgGIAa0FkgEDNy4xmAEAoAEByAEBwAEB&sclient=products-cc I also updated the post 161 in JmP's sticky, (we all should learn to read that thread) https://legacygt.com/forums/showthread.php/idea-web-links-saved-various-parts-219238p5.html Edited June 8, 2022 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
