mzsinko84 Posted December 14, 2020 Share Posted December 14, 2020 I have an 05 lgt and I want keep the AWD but I also want to be able to chose RWD, I’m thinking a different Power Transfer Case but I’m not 100% sure, could I get a bit of help about what to do? Link to comment Share on other sites More sharing options...
Tehnation Posted December 14, 2020 Share Posted December 14, 2020 (edited) probably be cheaper to just buy a different car at that point! you would need a dccd controller, Driver's Control Centre Differential. Maybe a transmission... not sure about how the dccd stuff works exactly so I'm not sure if it can go full 100% rear. Edited December 14, 2020 by Tehnation Link to comment Share on other sites More sharing options...
Underdog Posted December 14, 2020 Share Posted December 14, 2020 (edited) There are rear-biased center diff options, but nothing that lets you change the inherent torque split on the fly like you are describing. DCCD controls lock between the front and rear axles, but that affects the relative speed of the axles, not the torque output. Changing to RWD requires mechanical changes to your transmission that can’t be switched on/off (search “RWD conversion spool”). Edited December 14, 2020 by Underdog The Crimson Dynamo Link to comment Share on other sites More sharing options...
mzsinko84 Posted December 17, 2020 Author Share Posted December 17, 2020 I don’t want to change or alter the torque split, I just want find a little more to the rear wheels like a 35/65, 30/70, 25/75 and or maybe a 20/80 but I haven’t looked up center differential with DCCD option. Link to comment Share on other sites More sharing options...
dgoodhue Posted December 17, 2020 Share Posted December 17, 2020 It sounds like you are looking for a STI transmission swap with a DCCD controller. Link to comment Share on other sites More sharing options...
Underdog Posted December 17, 2020 Share Posted December 17, 2020 There are options for the 5MT as well. I have a 5MT DCCD with a 35:65 split (link). Cusco makes (or used to make) an open center diff with the same torque split. 6MT swap would open up more options but will cost a lot more. The Crimson Dynamo Link to comment Share on other sites More sharing options...
mzsinko84 Posted December 18, 2020 Author Share Posted December 18, 2020 I don’t have money on my side so I have to do things or I have to get things as cheap as I can. Just out of curiosity, does the 35/65 split work with an automatic transmission? Link to comment Share on other sites More sharing options...
mzsinko84 Posted December 18, 2020 Author Share Posted December 18, 2020 My current transmission has automatic, sport mode which shifts at higher/sportier rpm and manual mode. Link to comment Share on other sites More sharing options...
whitetiger Posted December 18, 2020 Share Posted December 18, 2020 ^no. the 5eat in the GT already has a 45/55 split VTD center. the cusco tarmac center that UD mentioned would be a downgrade and requires a FLSD to function properly, and the JDM DCCD unit along with the cusco unit is only for the 5MT. There are no easy solutions for doing what you want, especially if you say you don't have money on your side. Link to comment Share on other sites More sharing options...
boxkita Posted December 18, 2020 Share Posted December 18, 2020 if you have no money & an LGT, nothing is easy. Just keeping it running will absorb most of your paycheck Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted December 18, 2020 Share Posted December 18, 2020 My current transmission has automatic, sport mode which shifts at higher/sportier rpm and manual mode. I don’t have money on my side so I have to do things or I have to get things as cheap as I can. Just out of curiosity, does the 35/65 split work with an automatic transmission? Any reason for wanting the rearward split? Cause i'm guessing drift? Which has been determined to be the causation of many posts of "help, my engine failed, how do i get a cheap replacement because I'm broke" tssfab.net & subaru gears sell rwd conversion kits. Neither are cheap...think current KBB of your car Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
whitetiger Posted December 18, 2020 Share Posted December 18, 2020 i have a feeling this is gonna turn in to an EJ205X thread Link to comment Share on other sites More sharing options...
boxkita Posted December 18, 2020 Share Posted December 18, 2020 I miss the sammich threads. This is a McRib special here Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
lilredwagon Posted December 19, 2020 Share Posted December 19, 2020 If you're trying to make it more tail happy, you'll need a rear LSD as well. The stock VLSD won't do. You can slide a lot of RWD cars with an open diff, butt a Subaru is very front heavy, and usually lifts the inside rear when you setup the swaybars to be more rotation-friendly. With the stock VLSD, you'll just lift the inside tire and spin it in the air. I say this from experience. I've had my 5sp turned RWD by welding the center diff, and you can slide it, but it's super unpredictable with the stock rear diff. You can pretty much only do donuts with that setup. Now, it has the version 8 JDM 6sp with DCCD and a Cusco rear LSD. That transmission has a 35:65 geared center split (not all 6 speeds are split like that), a torsen LSD on the front, a Cusco rear, and a DCCDpro controller, it works well. The thing is that it still isn't stupid easy like a high powered RWD car. It's a grip car, so there's that, but you need to do a clutch kick to get it sideways, but once it's there, it's beautifully controllable. It also has 420whp, which is also necessary to keep things cooking. It's a road course car, so it would probably be easier to drift if it was actually built as a drift car, but the point here is that it'll take much more than just center diff torque split to make it a drift car. Link to comment Share on other sites More sharing options...
mzsinko84 Posted December 19, 2020 Author Share Posted December 19, 2020 A drift car is exactly what I’m looking to do with my car lil’redwagon. In all honesty, I want to be able to give my car some gas and feel the rear end start to slide out but keep my car under control. I know if I want more of a drift car I should get a manual transmission but that won’t happen for a while. Link to comment Share on other sites More sharing options...
boxkita Posted December 19, 2020 Share Posted December 19, 2020 a cheap set of super high mileage tires would be easier. Especially if they were skinny. Keep in mind drifting is really hard on the drivetrain. Blowing your engine or transmission is a foregone conclusion Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
lilredwagon Posted December 19, 2020 Share Posted December 19, 2020 (edited) If you actually want a drift car, it would be more economical for you to just buy a drift car and keep your LGT as your daily. As mentioned, you're going to go through engines and transmissions, in addition to body panels and whatever else gets messed up in the many crashes you endure while learning the car. I'm not trying to be a buzzkill on your idea - sliding a car is fun - but just consider that you'll be sinking a few grand into an LGT just to get it to slide, and when it does, it's not the best platform for it, so when it goes, it won't be with ballerina-like grace. Whereas you use the same amount of money and get a beater 240, E30, Miata, etc, and you'd already be mostly there. And when it's in the shop (it'll be in the shop a lot unless you plan on getting good at doing bodywork in your driveway), you can drive your LGT. Edit: And ignoring what car you're actually going to put it on, if you want a predictable breakaway of the rear end, you'll need a mechanical LSD. Apparently these new cars with the E-LSDs work well enough, but I don't imagine you're talking about $80K+ cars here. Below that, open, VLSDs, and even some Torsen diffs, are all unpredictable relative to a mechanical LSD. They are usually a large contributor to when a car gets a reputation of having snap oversteer. Edited December 19, 2020 by lil'redwagon Link to comment Share on other sites More sharing options...
dwmccauley01 Posted December 20, 2020 Share Posted December 20, 2020 Don't know where the idea of subarus being drift cars came from. However, I would just find some dirt or gravel roads to slide around a bit on. The whole idea of subarus awd is to not spin the back tires Sent from my SM-G970U using Tapatalk Link to comment Share on other sites More sharing options...
boxkita Posted December 20, 2020 Share Posted December 20, 2020 Do it, post video Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Chocoholic005 Posted December 20, 2020 Share Posted December 20, 2020 Don't know where the idea of subarus being drift cars came from. Link to comment Share on other sites More sharing options...
mzsinko84 Posted December 20, 2020 Author Share Posted December 20, 2020 I don’t know this but does my car have a DCCD? I’m assuming it does because my transmission has 3 modes. Oh yeah, I want to be able to do burnouts and wheel spins which pretty much the exact same thing. Link to comment Share on other sites More sharing options...
Chocoholic005 Posted December 20, 2020 Share Posted December 20, 2020 I don’t know this but does my car have a DCCD? No; DCCD is a center differential specific adjustment which your vehicle does not have. Link to comment Share on other sites More sharing options...
Underdog Posted December 20, 2020 Share Posted December 20, 2020 I feel like this was already mentioned... The Crimson Dynamo Link to comment Share on other sites More sharing options...
dwmccauley01 Posted December 20, 2020 Share Posted December 20, 2020 Fair enough lol Sent from my SM-G970U using Tapatalk Link to comment Share on other sites More sharing options...
boxkita Posted December 21, 2020 Share Posted December 21, 2020 that's obviously the cheapest way to do it. I mean engine swaps are child's play these days. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
