robburns201 Posted April 30, 2018 Share Posted April 30, 2018 So today I was sitting at lunch in my started car like 30mins and when I went to shut her off I gave it a quick rev before shutting off and noticed some smoke out tail pipes...So I started it back up and more smoke smelling like oil...My first thought is ringland failure so on my way home I put on roughness cyl 1,2,3,4 and started her but I have ZERO roughness on all cylinders...So I limped her home while keeping an eye on the AP. When I got home again no roughness in any cylinder....Please any thoughts on what the smoke could be? Maybe Turbo? IDK...thank you in advance Sent from my 0PJA2 using Tapatalk Link to comment Share on other sites More sharing options...
relative4 Posted May 1, 2018 Share Posted May 1, 2018 I don't know why you're smoking, but I know Max is about to start preaching on you for idling half an hour. Link to comment Share on other sites More sharing options...
robburns201 Posted May 1, 2018 Author Share Posted May 1, 2018 What's so bad? Besides bad mileage... Sent from my 0PJA2 using Tapatalk Link to comment Share on other sites More sharing options...
robburns201 Posted May 1, 2018 Author Share Posted May 1, 2018 And just a FYI this was a lot of smoke not a drag of vapor cig...and diminished after 30sec Sent from my 0PJA2 using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted May 1, 2018 Share Posted May 1, 2018 First reason is, it's illegal in CT to idle a car for more then 3 minutes. Its a pollution thing. second, it's a gravity thing, think about the way the pistons side horizontally and what gravity does. Let us know how much oil smoke you get on the morning start up today. You may want to get out after stating and smell the smoke. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
robburns201 Posted May 1, 2018 Author Share Posted May 1, 2018 First reason is, it's illegal in CT to idle a car for more then 3 minutes. Its a pollution thing. second, it's a gravity thing, think about the way the pistons side horizontally and what gravity does. Let us know how much oil smoke you get on the morning start up today. You may want to get out after stating and smell the smoke.I did exactly that. I watched the car this morning and nothing for smoke and smelled it also and nothing...so your saying this could have been excess fuel or oil sitting in the cylinder walls? Or maybe in the Turbo and when I revved it yesterday it cleaned it out? Sent from my 0PJA2 using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted May 1, 2018 Share Posted May 1, 2018 While driving in today I was thinking may be oil vapors got built up in the PCV system. Could be the combination of those things you mentioned. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
