robburns201 Posted December 26, 2017 Share Posted December 26, 2017 Good day all and Happy Holidays ... I am planning on doing my PS pump and was wanting to know if doing the PS Rack is a must or just recommended? And if it's a good idea to change it would there be a direct swap for it (sti/wrx)??? Sent from my 0PJA2 using Tapatalk Link to comment Share on other sites More sharing options...
Wasted Potential Posted December 26, 2017 Share Posted December 26, 2017 Did pump fail and rack was ran dry at all? If so, replace rack with quality piece. Not auto parts cheapie reman. Link to comment Share on other sites More sharing options...
robburns201 Posted December 26, 2017 Author Share Posted December 26, 2017 Did pump fail and rack was ran dry at all? If so, replace rack with quality piece. Not auto parts cheapie reman.No I didn't run it dry...but when turning it pulsates...IDK if that is Just pump or what...I might buy Oem reman cause I'm sure new Oem is bonkers$ Sent from my 0PJA2 using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted December 26, 2017 Share Posted December 26, 2017 FWIW, my reman from NAPA is doing fine 18 month's later. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Wasted Potential Posted December 26, 2017 Share Posted December 26, 2017 I had a Dorman (I think) from advance auto and another from autozone with notchiness/ not smooth on both. Weird, bought a different car and didn't have to think about the other rack haha. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 26, 2017 Share Posted December 26, 2017 Is the drive belt tight ? or do figure 8's in a parking lot going lock to lock to get the air out. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
robburns201 Posted December 27, 2017 Author Share Posted December 27, 2017 I'm going to do pump regardless this weekend...I will do the figure 8 after for sure...thanks Max and wasted for your info...if it is still notch then a new track it is... Sent from my 0PJA2 using Tapatalk Link to comment Share on other sites More sharing options...
robburns201 Posted January 2, 2018 Author Share Posted January 2, 2018 Is there a filter on the guy's? I want to do this today but if there is filter I have to get it... Sent from my 0PJA2 using Tapatalk Link to comment Share on other sites More sharing options...
KRM Posted January 2, 2018 Share Posted January 2, 2018 You could get one from any parts store. Relatively cheap Link to comment Share on other sites More sharing options...
robburns201 Posted January 2, 2018 Author Share Posted January 2, 2018 Is there a Oem filter? Or you talking about aftermarket? Sent from my 0PJA2 using Tapatalk Link to comment Share on other sites More sharing options...
apexi Posted January 3, 2018 Share Posted January 3, 2018 I don't believe there is any oem filter in our power steering systems. Link to comment Share on other sites More sharing options...
aj_mariner Posted January 3, 2018 Share Posted January 3, 2018 I think there is a filter next to the battery, in the cavity. Don’t remember if it’s PS or brake. Link to comment Share on other sites More sharing options...
robburns201 Posted January 3, 2018 Author Share Posted January 3, 2018 I know there is tranny filter by battery...I think it might be in line filter for ps but I'm not positive...guess I should call the stealer ship Sent from my 0PJA2 using Tapatalk Link to comment Share on other sites More sharing options...
