Ninjacheezit Posted September 26, 2019 Share Posted September 26, 2019 So some of you might know I have a reman engine from LKQ. It looks like the cam and crank seals are leaking. I don’t plan on the engine lasting long from their reputation. So I have a engine savings on the side. But basically should I do the most I can to make it last longer? I would assume crank and cam seals plus a timing kit would be needed. But I still don’t know what kind of pistons they used when they rebuilt it. So I’m not sure if it would be worth it in the long run. Anyone have any input? Keep saving? Or take some out and try and make this engine last. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 26, 2019 Share Posted September 26, 2019 Who did the Tune ? For the oil leaks have you replaced the PCV valve ? When the oil leaks are fixed use good oil and filters and keep up with the routine maintenance Engine life is all in the Tune. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Ninjacheezit Posted September 26, 2019 Author Share Posted September 26, 2019 Tpg tuning I just replaced it today to see if it helps any. Oil I use rotella t6 5w-40 and Subaru filter So you think it’s worth trying to keep this engine alive? Even if they used some Chinese knockoff pistons? Or whatever else. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 26, 2019 Share Posted September 26, 2019 If the Tuner knows what's in the engine, they can tune it accordingly. Or plan on saving $4000-5000 to do a ej257 and etc to do it right. Then again, the car is 12y/o... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Ninjacheezit Posted September 26, 2019 Author Share Posted September 26, 2019 Also for all I know the engine could be a good one. I’m just going off of what I read about them online reviews. About most people say they leak. Some say they seized up in a year. And a few people actually say theirs been going for some years now. Do I think they used oem parts? Nope just wouldn’t seem practical for them to do that to get their profit in. But that’s what has me on the ropes about throwing a timing belt kit and some seals at this engine and the chance of it turning around and crapping out at me soon after lol I’m one of those people that always thinks about the worst possibly outcomes. Link to comment Share on other sites More sharing options...
Ninjacheezit Posted September 27, 2019 Author Share Posted September 27, 2019 Also the black plastic y on the pcv valve I ended up cracking it. Right now I have it clamps into the black hose and connecting to the manifold. Would this be fine or should I order the plastic piece and hook it back up to the turbo inlet? Link to comment Share on other sites More sharing options...
Max Capacity Posted September 27, 2019 Share Posted September 27, 2019 (edited) You might be able to get that piece from a local junk yard...or does this help any... https://www.google.com/search?biw=1274&bih=871&tbm=shop&ei=n9CNXYfaGoGZ_QbozoHoCQ&q=pcv+valve+2005+subaru+legacy+GT&oq=pcv+valve+2005+subaru+legacy+GT&gs_l=psy-ab-sh.3...8516.22512.0.23182.30.25.4.1.1.0.101.1892.24j1.25.0....0...1c.1.64.psy-ab-sh..0.4.272...0.0.OcwvD3BT8KE Edited September 27, 2019 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rhino6303 Posted September 27, 2019 Share Posted September 27, 2019 Also the black plastic y on the pcv valve I ended up cracking it. Right now I have it clamps into the black hose and connecting to the manifold. Would this be fine or should I order the plastic piece and hook it back up to the turbo inlet?The pcv and plastic housing can be had for about $10 from a dealer. Subaru PN 11819AA001. Link to comment Share on other sites More sharing options...
Ninjacheezit Posted September 27, 2019 Author Share Posted September 27, 2019 Ya but I had to get the car running while it’s on order. Subaru won’t have it until Monday or Tuesday Link to comment Share on other sites More sharing options...
Ninjacheezit Posted September 27, 2019 Author Share Posted September 27, 2019 I just liked how getting rid of that hose cleaned up under there a little. But if I really need it or it’ll do harm I have no problem getting it from Subaru and putting it back in. Link to comment Share on other sites More sharing options...
jtroop12 Posted October 14, 2019 Share Posted October 14, 2019 Lots of good info in here. Thanks Link to comment Share on other sites More sharing options...
