fehler1977 Posted July 3, 2020 Share Posted July 3, 2020 Does anyone have any thoughts on the ihi vf40 turbo. I'm not seeing a lot of information online about this manufacturer one way or the other. Good or bad. Has anyone had it any experience with this Turbo Sent from my SM-J336AZ using Tapatalk Link to comment Share on other sites More sharing options...
Chocoholic005 Posted July 3, 2020 Share Posted July 3, 2020 Pretty much everyone with an 05-06 has experience with it, since its the stock turbo. Do a site search, there's more information than you could ever need. Link to comment Share on other sites More sharing options...
Infosecdad Posted July 3, 2020 Share Posted July 3, 2020 IHI VF-40 was the stock turbo for 2005/2006 LGTs. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 3, 2020 Share Posted July 3, 2020 The smart move is to do what most of us have, Cobb AP stage 2, with 3" down pipe, catless up pipe. custom tune. I replaced the vf40 with a vf52, 150,000 miles ago. Vf52 is still great. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ttnio Posted July 3, 2020 Share Posted July 3, 2020 i would pm and ask JMP,about the VF40's. Link to comment Share on other sites More sharing options...
fehler1977 Posted July 9, 2020 Author Share Posted July 9, 2020 i would pm and ask JMP,about the VF40's.Thanks for the info. It seems like everyone has moved away from the vf40. I will probably do the same. Sent from my SM-J336AZ using Tapatalk Link to comment Share on other sites More sharing options...
Berge56 Posted July 15, 2020 Share Posted July 15, 2020 JMP's custom VF40 is a fantastic reliable turbo. I installed one on my buddies car and it spools very quick and is a blast on the street. Link to comment Share on other sites More sharing options...
ttnio Posted July 15, 2020 Share Posted July 15, 2020 JMP VF40 is on my maintenance want lists. Link to comment Share on other sites More sharing options...
ashwinearl Posted July 16, 2020 Share Posted July 16, 2020 I have JMP Vf40 sitting on my bench. It was replaced with a JMP VF52. It has 60k miles on it and is available. Link to comment Share on other sites More sharing options...
Scoobiidoo Posted July 16, 2020 Share Posted July 16, 2020 I have a VF40 turbo with a stuck opened wastegate. Is it an easy repair or repairable? Thanks Link to comment Share on other sites More sharing options...
