Richard_Mtl Posted January 4, 2016 Share Posted January 4, 2016 I drive a 2007 Legacy 2.5i and I've noticed a significant drop in my my gas mileage as the weather gets cold. I've seen a drop of around 25-30%. I've read online that "winter gas" is a contributor as well cold weather starts, but 30% drop seems extreme to me. Anyone else experience the same? Link to comment Share on other sites More sharing options...
rmoore5 Posted January 4, 2016 Share Posted January 4, 2016 My mileage usually drops from 28 to 26.5 mpg, my drive is 50 miles. Shorter drives would suffer more I would think. Link to comment Share on other sites More sharing options...
orndog Posted January 4, 2016 Share Posted January 4, 2016 I have been complaining about this in my 5th gen since I got it. It is not winter gas. I took 2 identical trips this year, one at Thanksgiving when it was cold, and one at Christmas with the inexplicable 70 degree streak. Long trips from Atlanta, GA to west TN to middle TN back to west TN and back to Atlanta. In the cold I got 25.5 average, in the warm I got 29.8 (calculated and within .3 of the dash computer I have adjusted to be close to correct). Link to comment Share on other sites More sharing options...
Richard_Mtl Posted January 4, 2016 Author Share Posted January 4, 2016 Does anyone else see mileage drops as high as 25-30%? Keep in mind that this is mostly city driving. Link to comment Share on other sites More sharing options...
Picky1 Posted January 4, 2016 Share Posted January 4, 2016 I always see a 2-3 MPG drop in the winter. Guess the 2.5i has "shrinkage"? Link to comment Share on other sites More sharing options...
housemusic1 Posted January 4, 2016 Share Posted January 4, 2016 On the flip side, be grateful that you don't drive a 3.0, I get 15 mpg! Link to comment Share on other sites More sharing options...
theflystyle Posted January 4, 2016 Share Posted January 4, 2016 On the flip side, be grateful that you don't drive a 3.0, I get 15 mpg! Yeah its low for us, but 15 is really low Link to comment Share on other sites More sharing options...
pnmid Posted January 4, 2016 Share Posted January 4, 2016 Some of lower winter gas mileage is due to increased drag from thicker drivetrain (rear end, transmission) fluids and lower tire pressures, which most people forget to check (it decreases about 1 pound per 10 degrees) and to raise when it gets colder. Minutes after your car leaves an attached garage, the pressure drops by 2-3 psi. In addition, the dash computer is optimistically inaccurate. Link to comment Share on other sites More sharing options...
SBT Posted January 4, 2016 Share Posted January 4, 2016 Winter blends are fully rolled-out by 30 September and usually remain in effect until March 31st. I have always lost 3-5mpg with my first tank and subsequent tanks of winter blend. Notice improved MPGs with first tank of Summer blend. And, FWIW, my actual mileage doesn't settle-in on any of my Subes until >20K miles. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
98legwag Posted January 6, 2016 Share Posted January 6, 2016 My 3.0R gets about 19-20 mpg in the winter and 22-23 mpg when its warmer. Link to comment Share on other sites More sharing options...
theflystyle Posted January 7, 2016 Share Posted January 7, 2016 My 3.0R gets about 19-20 mpg in the winter and 22-23 mpg when its warmer. Pretty much what I get. And I am anal about cleaning MAF/Filter/Plugs/etc but drive spiritedly Link to comment Share on other sites More sharing options...
housemusic1 Posted January 7, 2016 Share Posted January 7, 2016 Is anybody else with a 3.0 or 3.6 running premium fuel? I didn't buy into the premium gas myth for a long time, then started tuning, and had a lot of pinging. Switched to premium, and it feels like a completely different vehicle. Better gas mileage too! Link to comment Share on other sites More sharing options...
98legwag Posted January 7, 2016 Share Posted January 7, 2016 Pretty much what I get. And I am anal about cleaning MAF/Filter/Plugs/etc but drive spiritedly I clean the MAF and air filter once a year. I did the spark plugs when I bought the car with about 65K on it. Its got 77K now. Is anybody else with a 3.0 or 3.6 running premium fuel? I didn't buy into the premium gas myth for a long time, then started tuning, and had a lot of pinging. Switched to premium, and it feels like a completely different vehicle. Better gas mileage too! I only run premium. Which is 93 in my area. Link to comment Share on other sites More sharing options...
SBT Posted January 7, 2016 Share Posted January 7, 2016 3.0 H6es were designed to be run on 91+ premium fuel (higher CR) while the 3.6 H6es were designed to be run on 87 regular fuel (lower CR). - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
DonnyJagaru Posted January 7, 2016 Share Posted January 7, 2016 I'm doing better than you guys. Averaging 29.4 mpg (US gallon) right now and its below freezing. I do however commit the cardinal sin of either warming my engine up for 5 minutes or generally taking it easy until the engine is fully warmed up. Update: Last night I checked and I'm at 28Mpg for this tank. I'll attribute that to the weather creating more stop'n'go. My car is manual BTW. Link to comment Share on other sites More sharing options...
theflystyle Posted January 8, 2016 Share Posted January 8, 2016 Only run premium on mine FYI, the MPG for our cars is apparently 17/24. Its been so long since I thought about it I had to look it up. http://www.cars101.com/subaru/legacy/legacy2008.html#mechanical Link to comment Share on other sites More sharing options...
98legwag Posted January 8, 2016 Share Posted January 8, 2016 Only run premium on mine FYI, the MPG for our cars is apparently 17/24. Its been so long since I thought about it I had to look it up. http://www.cars101.com/subaru/legacy/legacy2008.html#mechanical From what I heard they were tested in Sport mode on the SI Drive. I am not sure if its true or not. Link to comment Share on other sites More sharing options...
NORULZleggy Posted January 13, 2016 Share Posted January 13, 2016 With a fresh oil change, and K & N filter, proper tire inflation, full tank of gas, with 150K miles I get about 25-26mpg on a highway trip doing 78 cc on. that's not bad in my book. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted January 16, 2016 Share Posted January 16, 2016 always see a slight drop in winter time 1 winter fuel sucks 2 air is much denser and you need moar fuel. Link to comment Share on other sites More sharing options...
