suds2250 Posted May 18, 2012 Share Posted May 18, 2012 Event: Dyno baseline Location: IPS Motorsports Columbus OH Date: 04/30/2012 Ambient Temp: 85deg Elevation: 910' Weather: Clear Car: 2005 Subaru Legacy GT Limited Wagon Tuner: Cobb StreetTuner Dyno Info: Dynojet Transmission: 5 speed Gear: 3rd Peak Horse Power at RPM: 334.4hp @ 5400rpm Peak Torque at RPM: 359 ft lbs @ 4300rpm Baseline hp/tq for a stock on same dyno 2011 WRX Stage 2 was 272hp / 317 ft lbs Target Boost: 21.0psi Target AFR: 11.75 SAE Correction factor: 1.02 Fuel: 93 octane Engine/Power Modifications: - Deadbolt VF22 -1820 with vf40 compressor cover Labonte Methanol injection, Wossner 4032 pistons, PTP turbo blanket One step colder plugs Borla Header, Crucial uppipe, Crucial catted downpipe, Magnaflow 2.5 in mufflers Prodrive 3-port EBCS AEM Intake TGV deletes Perrin Top mount intercooler Walbro fuel pump Deatchwerks 740 injectors Driveline Modifications: ACT clutch, WRX flywheel Suspension Modifications: JDM Spec B Bilsteins with Prova springs Other Modifications: Rota Formula Mesh 18x8 Dyno.pdf 335HP/360Tq VF-22/1820 clone with Meth Link to comment Share on other sites More sharing options...
blongo804 Posted May 18, 2012 Share Posted May 18, 2012 Wow all on a TMIC. Very nice numbers! Must be a blast to drive Link to comment Share on other sites More sharing options...
suds2250 Posted May 18, 2012 Author Share Posted May 18, 2012 Yes it is! 335HP/360Tq VF-22/1820 clone with Meth Link to comment Share on other sites More sharing options...
