Zootal Posted March 24, 2019 Share Posted March 24, 2019 I have a 2016 Forrester, and it came with just one key/remote. The dealer wants a couple hundred dollars for a replacement, and while aftermarket remotes are cheap, programming costs $100+. Is there no other way? And why so much to program one of these? Link to comment Share on other sites More sharing options...
Norskie Posted March 24, 2019 Share Posted March 24, 2019 I had this problem with my WRX. There is no 'cheap' solution, but the least expensive option was to buy two blank keys on Amazon (which had used OEM internals, $40 each), had a local hardware store cut them so they fit in the ignition ($10), and then took them to Subaru for programming ($80 - they will program ALL your keys). EDIT: Not all hardware stores will cut car keys because they are harder than standard house keys and wears out the cutting equipment faster. A local locksmith should be able to do it though. Assuming you don't have the laser-cut keys, i.e. those with channels in the blank, not the standard external-ridge keys. Link to comment Share on other sites More sharing options...
