Smithcraft Posted December 9, 2018 Share Posted December 9, 2018 Hello, The Q300 is in, and the passenger side is perfectly spaced in the opening, but the drivers side is almost right up against the bumper (towards the centerline of the car). Are there an suggestions for getting the drivers side a bit more even in the opening? Thanks! SC 1994 Legacy MI 2008 Legacy GT specB 2023 Crosstrek Limited Link to comment Share on other sites More sharing options...
traildogck Posted December 9, 2018 Share Posted December 9, 2018 Bend a hanger...or 2 CKE SSP product information and sales : chris.ckessp@gmail.com Link to comment Share on other sites More sharing options...
Infosecdad Posted December 9, 2018 Share Posted December 9, 2018 Longer hanger, rotate the mid-pipe slightly, bend hanger. Stuff like that. Link to comment Share on other sites More sharing options...
Marvick08GT Posted December 10, 2018 Share Posted December 10, 2018 The q300 fits like $hi!.... /Rant Link to comment Share on other sites More sharing options...
Andy_Mac Posted December 11, 2018 Share Posted December 11, 2018 Mine has about a dozen cable ties squashing and pulling the rubber hangers to get it to fit perfect. Far from ideal but quad tip options are few and far between 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
m sprank Posted December 11, 2018 Share Posted December 11, 2018 Get creative. Its an Invidia. They did start as a knock-off company. Somewhere along the line they gained legitimacy. But the products are still hit and miss. Link to comment Share on other sites More sharing options...
SubOperator Posted December 12, 2018 Share Posted December 12, 2018 Longer hanger, rotate the mid-pipe slightly, bend hanger. Stuff like that. This^^^^. Depending on the hardware used for putting it together there is a fair amount of play between central pipe, Y pipe and the mufflers. I went with M10 bolts, but I believe Q300 holes will take M12 easy. Smaller the number, more play room. Also hangers on muffler cans are much more under an angle compared to stock. may be just moving the rubber hangers on hangers will alter the position. 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 248K 2007 B9 Tribeca Limited DGM - 258K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted December 12, 2018 Share Posted December 12, 2018 I picked up mine used and it has aligned perfectly, I also used all NEW poly hangars 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
Smithcraft Posted December 12, 2018 Author Share Posted December 12, 2018 I don't see how you can rotate either of the mid pipes. The next time I have it up in the air I'll try and see what I can do about rotating them. SC 1994 Legacy MI 2008 Legacy GT specB 2023 Crosstrek Limited Link to comment Share on other sites More sharing options...
Max Capacity Posted December 12, 2018 Share Posted December 12, 2018 I don't see how you can rotate either of the mid pipes. The next time I have it up in the air I'll try and see what I can do about rotating them. SC There is play in the bolt holes, just loosen them a bit so you can adjust the pipes. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Smithcraft Posted December 13, 2018 Author Share Posted December 13, 2018 There is play in the bolt holes, just loosen them a bit so you can adjust the pipes. It's a super tight fit, so I'm not sure about the play, but I'll see what all I can do. SC 1994 Legacy MI 2008 Legacy GT specB 2023 Crosstrek Limited Link to comment Share on other sites More sharing options...
