djemzine Posted December 2, 2018 Share Posted December 2, 2018 Anyone know if these fit the stock cat back/y pipe off a 2.5i NA or LGT? Or would it need some custom work? Link to comment Share on other sites More sharing options...
Max Capacity Posted December 2, 2018 Share Posted December 2, 2018 They look like they might. Hard to know without knowing what they came off or the part number. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Infosecdad Posted December 2, 2018 Share Posted December 2, 2018 If those are the HKS Silent Hi-Power for BP5 (as indicated by the chalk), then yes, they will work with the stock y-pipe. Question is if they are for sedan or wagon. JDM wagon is short on US wagon, unless you have a JDM rear bumper. Link to comment Share on other sites More sharing options...
ttnio Posted December 2, 2018 Share Posted December 2, 2018 how much? Link to comment Share on other sites More sharing options...
djemzine Posted December 4, 2018 Author Share Posted December 4, 2018 If those are the HKS Silent Hi-Power for BP5 (as indicated by the chalk), then yes, they will work with the stock y-pipe. Question is if they are for sedan or wagon. JDM wagon is short on US wagon, unless you have a JDM rear bumper. Thanks. I'll be sure to ask the shop if it came off a wagon or sedan. Mine is a wagon USDM. So the question is, even if it came off a sedan, it will be fine? Link to comment Share on other sites More sharing options...
djemzine Posted December 4, 2018 Author Share Posted December 4, 2018 how much? About $400 CDN from what I was told. Link to comment Share on other sites More sharing options...
Infosecdad Posted December 4, 2018 Share Posted December 4, 2018 If the “BP5” is accurate, then it’s for a JDM wagon. They should work, they’ll just be tucked back a few inches. It means you may get a little more drone or exhaust fumes. Which may or may not be a problem for you, just depends. I ran a set for a while, they soothed my rear bumper a bit. Ended up getting a JDM rear bumper and they were perfect. Link to comment Share on other sites More sharing options...
djemzine Posted December 5, 2018 Author Share Posted December 5, 2018 If the “BP5” is accurate, then it’s for a JDM wagon. They should work, they’ll just be tucked back a few inches. It means you may get a little more drone or exhaust fumes. Which may or may not be a problem for you, just depends. I ran a set for a while, they soothed my rear bumper a bit. Ended up getting a JDM rear bumper and they were perfect. As long as there's no exhaust fumes into the cabin via the vents, I am happy haha. God I hated that issue when I had the header leak. All went away when I swapped it with a JDM header off a 2.5i Legacy from the same year. I don't mind the extra drone. My main car is a 15 WRX and the exhaust setup on that is quiet loud and drones haha. Are the JDM rear bumpers direct fit? What else is required? Link to comment Share on other sites More sharing options...
revilo Posted December 10, 2018 Share Posted December 10, 2018 I've got an HKS ES Premium axelback on my 04 JDM wagon. There is at least an inch exposed out the back of the bumper. I wager that under a USDM bumper, it should look fine. Post pics when it's done! Link to comment Share on other sites More sharing options...
