need bb Posted May 1, 2017 Share Posted May 1, 2017 A year ago I snapped a bolt on the bumper/headlight bracket assembly while trying to adjust my headlight's position. I thought I would finally drill it out and replace it. The issue is I need to determine the part number for the replacement bolt. I had a baggy with the 10mm broken bolt and then two other bolts which I imagine are part of the assembly. I can't remember exactly where the bolt was, but it was 10mm and I think it is either one of these circled in the picture. I could find pictures of the entire bumper/headlight bracket assembly online so hoping someone has an idea on what bolt I need to purchase. Link to comment Share on other sites More sharing options...
madrig Posted May 1, 2017 Share Posted May 1, 2017 047406160 Link to comment Share on other sites More sharing options...
need bb Posted May 3, 2017 Author Share Posted May 3, 2017 Awesome! Thank you Link to comment Share on other sites More sharing options...
Max Capacity Posted May 3, 2017 Share Posted May 3, 2017 FWIW, go to any hardware store and buy a 6mmx 1.25 bolt about a 1/2 to 3/4 inch long and washer and put it in. it doesn't have to be an OEM bolt. You can buy plastic kit with assorted nuts, bolts and washers from places like Harbor Fright and many other places that will work fine for most replacement hardware. You may want to look here, http://estore.subarupartswarehouse.com/a/Subaru_2005_Legacy25L-TURBO-5MT-4WDGT-Wagon/_52016_6025807/HEAD-LAMP-05MY-07MY/B13-840-01.html or go back a page and click on the "Body" parts and look there. http://estore.subarupartswarehouse.com/a/Subaru_2005_Legacy25L-TURBO-5MT-4WDGT-Wagon/_51505_6024785/FRONT-BUMPER-05MY-07MY/B13-590-01.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
