engineerdad Posted June 5, 2020 Share Posted June 5, 2020 Hi everyone. First I apologize if there is a post for this problem, but I couldn't find it. I have a 2008 Legacy 3.0R, last fall the AC stopped working and I forgot about it until now, it is getting hot. My previous Impreza had needed a recharge which I did easily and figured I would do it again to my Legacy. This time, things are not so simple. First I started the car and turned on the AC. The compressor did not start up and I put the gauge from the refrigerant can on the low pressure line. It read high pressure in the red (not really expecting anything meaningful without the compressor running). Then I found the relay and pulled it. The relay tested fine. I tested the socket and found no signal power. I jumpered the relay contacts, the AC clutch engaged and I got cold air inside. Also, the refrigerant low pressure gauge started to read green at this point. So it seems my system is fine, there something is stopping the car from engaging it. Any ideas? Is there a way to check the pressure sensor/switch? thanks! Tom Link to comment Share on other sites More sharing options...
apexi Posted June 6, 2020 Share Posted June 6, 2020 (edited) I wonder if the system is overcharged, and that's preventing it from turning on. I am an AC newbie though, and I can't remember what the low pressure value will be with the AC off. FSM also says to check "Fuse (M/B No. 8, F/B No. 22, 31)". more ac system specs https://legacygt.com/forums/showpost.php?p=5435476&postcount=14 Edit: I know "Doesn't respond promptly" doesn't fit your problem description, but.. I think the troubleshooting steps given might still be helpful. Also, this is what the lock sensor is supposed to look like, to find and check it https://www.subaruoutback.org/threads/05-h6-a-c-compressor-cluth-relay-not-getting-12v.424202/post-4874697 Edited June 6, 2020 by apexi Link to comment Share on other sites More sharing options...
FaithD Posted February 15, 2021 Share Posted February 15, 2021 I understand you pretty well... I have the same problem now and don't know what to do Link to comment Share on other sites More sharing options...
Infosecdad Posted February 15, 2021 Share Posted February 15, 2021 Hi everyone. First I apologize if there is a post for this problem, but I couldn't find it. I have a 2008 Legacy 3.0R, last fall the AC stopped working and I forgot about it until now, it is getting hot. My previous Impreza had needed a recharge which I did easily and figured I would do it again to my Legacy. This time, things are not so simple. First I started the car and turned on the AC. The compressor did not start up and I put the gauge from the refrigerant can on the low pressure line. It read high pressure in the red (not really expecting anything meaningful without the compressor running). Then I found the relay and pulled it. The relay tested fine. I tested the socket and found no signal power. I jumpered the relay contacts, the AC clutch engaged and I got cold air inside. Also, the refrigerant low pressure gauge started to read green at this point. So it seems my system is fine, there something is stopping the car from engaging it. Any ideas? Is there a way to check the pressure sensor/switch? thanks! Tom From what you are describing, wouldn't that point to either the relay actually not working correctly or the trigger signal is not reaching the relay. I would be tempted to swap the relay with a known good one to test that. If that doesn't work, then start chasing the signal wire. Recommend using the service manual to aid with troubleshooting if you don't have it already. Link to comment Share on other sites More sharing options...
Giniana Posted May 15, 2021 Share Posted May 15, 2021 Have you contacted the repair service? I think they can help you. Link to comment Share on other sites More sharing options...
Toji Posted May 15, 2021 Share Posted May 15, 2021 (edited) This can be a serious problem. You have contacted the repair service. Just this behavior of the air conditioner may not lead to the most pleasant outcome. I bought an air conditioner about a year ago, which began to work poorly after three months of work. But there was nothing serious, that is, the smell of burning or some strange sounds. Four months later, when it was turned on, it began to smell weird and warm air began to come out of it. Then I decided to search the Internet for what to do if aircon not cold. I found video tutorials on how to deal with this problem myself. Still, in my opinion, the best solution was to hand it over for repair. Edited May 18, 2021 by Toji Link to comment Share on other sites More sharing options...
ZosCols Posted July 26, 2021 Share Posted July 26, 2021 (edited) I also think that with such a problem it is better to address in repair service. Indeed, it can be a severe problem. And if you try something, you will aggravate the situation. It is better to entrust such things to professionals because all the techniques are fragile and require special care. Honestly, I don't try to repair myself, even an ordinary air conditioner at home. The more I would not go into, I wouldn't go into a machine. Moreover, now many services are specializing in repair and aircon chemical wash prices. They tackle problems of any complexity any and do their job quickly and efficiently. Edited August 4, 2021 by ZosCols Link to comment Share on other sites More sharing options...
jimmy1981 Posted August 2, 2021 Share Posted August 2, 2021 i have a question about my ac took it to the shop today had it flushed and they told me the cycling switch wasn’t putting power to the compressor he jumped the compressor just to show me it worked and it came right on blowing good cool air he gave me a part number of 1618 off some site. but can anyone tell me the actual name of that switch its the one on the drivers side behind the wheel well Link to comment Share on other sites More sharing options...
Swapstar Posted August 3, 2021 Share Posted August 3, 2021 i have a question about my ac took it to the shop today had it flushed and they told me the cycling switch wasn’t putting power to the compressor he jumped the compressor just to show me it worked and it came right on blowing good cool air he gave me a part number of 1618 off some site. but can anyone tell me the actual name of that switch its the one on the drivers side behind the wheel well I believe that is the high pressure switch. I have also run into this problem this past month and diagnosed all easily accessible switches and fuses and everything checkout ok. I still bought an relay just in case as it seems that after i tested the relays, the system started working properly. either way i am glad it is working properly for now. it is hot here in Houston. Link to comment Share on other sites More sharing options...
apexi Posted August 3, 2021 Share Posted August 3, 2021 (edited) The factory service manual just calls it a pressure switch, or triple pressure switch. I tried to find it at parts.subaru.com, but I think subaru makes you buy the whole pipe to get that sensor. I believe your mechanic knows of a place where he can just get the switch, without having to buy the whole pipe like subaru makes you do. I wish I knew what brand or something, I tried googling various words with 1618 and didn't get anything. Edit: Maybe it's this switch, Santech MT1618 https://www.autozone.com/cooling-heating-and-climate-control/a-c-switch/p/santech-a-c-switch-mt1618/121102_481672_8905 http://www.santech.com/downloads/flyers/LIT-0242_Santech_2012_New_MT_Products.pdf Other options when you cross reference the oem honda part number in the third image https://www.rockauto.com/en/partsearch/?partnum=80450-SFE-003 Edited August 3, 2021 by apexi Link to comment Share on other sites More sharing options...
08SpecB_DE Posted August 8, 2021 Share Posted August 8, 2021 I would check the control head first. A scanner should be able to tell you if the computer is recognizing the a/c switch as being on, which energizes the relay. Link to comment Share on other sites More sharing options...
Register a new accountSign in
