ktmrider Posted June 19, 2018 Share Posted June 19, 2018 Just swapped LGTs for my first auto equipped Subaru ( yes by choice, young driver getting license ). Trans shifted a bit weird and TC lockup was erratic. Made sure fluids were topped off and looked/smelled Ok. Had a noisy PS pump when cold, decided to swap the notorious o-ring and check hoses. Suction line was quite hard and had visible signs of leakage so I snipped 15mm off the end as a temp fix. PS way better but also noticed the trans "feels" a ton better including TC lockup. Assume the PS was sucking air all the time and putting a high(er) load on the engine. Is the 5EAT that sensitive to engine load? Link to comment Share on other sites More sharing options...
utc_pyro Posted June 19, 2018 Share Posted June 19, 2018 Yes. Look up the calculated torque table. Link to comment Share on other sites More sharing options...
