mijohnst Posted September 15, 2020 Share Posted September 15, 2020 (edited) Hello! I'm new here and glad to have found this forum. I purchased my son a 2008 Legacy 3R for his 16th birthday and although it has issues, I figured it would be a good "teach your kid to work on cars" project. It has many small problems but nothing we hopefully can't handle. I'm used to working on American cars so this will be a learning experience for me as well. The first issue I'd love to get some advice on is a fan module that someone hacked. It's a Denso 499300-3200 that the left fan was disconnected from. They also installed some killer wiring and connected it in some other kind of module. When the car starts the left fan goes full blast and never stops. I've attempted re-attach the left fan to where it was removed from but the fan never kicks on. The right fan seems to be fine connected to the Denso module. A bad module indication which is probably why it was hacked? Any recommendations where I should buy a used (possibly new) Denso module? Thanks again! Edited September 15, 2020 by mijohnst Link to comment Share on other sites More sharing options...
mijohnst Posted September 18, 2020 Author Share Posted September 18, 2020 Bump Link to comment Share on other sites More sharing options...
Rusty9 Posted September 18, 2020 Share Posted September 18, 2020 (edited) I would wager the fan control module is faulty and they did that to keep it running to prevent overheating. Probably a dealer only part, or comes connected to the entire fan unit itself.... https://estore.subarupartswarehouse.com/p/Subaru_2008_Legacy/AC-Condenser-Fan-Fan-and-Motor/49282689/73310AG02A.html or start calling your local junkyards to see if they have any 3.0 Legacy's around Edited September 18, 2020 by Rusty9 Link to comment Share on other sites More sharing options...
Max Capacity Posted September 18, 2020 Share Posted September 18, 2020 http://people.csail.mit.edu/ilh/vacation/ The service manual may be helpful. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
mijohnst Posted September 18, 2020 Author Share Posted September 18, 2020 (edited) Thank you guys for the information! I found one Legacy at our PYP place but when I got there the fans and module had been removed. It might have worked anyway because it was a 4 cylinder instead of the 6. I might have to bite the bullet and order from the dealer. Holy cow! Thank you for the manual Max! Edited September 18, 2020 by mijohnst Link to comment Share on other sites More sharing options...
