WileyKyle Posted August 15, 2011 Share Posted August 15, 2011 After my turbo died we cleaned out the metal, replaced the turbo and put in a prosport halo series oil pressure gauge. The oil pressure gets up to about 70 psi on the highway and drops to around 10 psi at idle. Otherwise in ranges anywhere in there depending on the engine rpm. Does this sound normal? Link to comment Share on other sites More sharing options...
bigleben Posted August 15, 2011 Share Posted August 15, 2011 I get that reading too at idle Correct me if I'm wrong but the oil pressure dashlight appears at ±4 psi which is already too late. Link to comment Share on other sites More sharing options...
frank_ster Posted August 15, 2011 Share Posted August 15, 2011 stock it will be about 40 psi idle . 10 psi hot idle is on the low side .. are codes poping up for the cam advance ? Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted August 16, 2011 Share Posted August 16, 2011 Mine is usually at about 20psi idle, cold or highway 80-90psi. I have my low pressure alarm set for 15psi. Could be your gauge is off. Also don't run a supposedly thin oil like Mobil 1 either. Link to comment Share on other sites More sharing options...
MrHellrais3R Posted August 16, 2011 Share Posted August 16, 2011 warmed up idle is normally around 40 and under throttle up to 95. Where did you mount your gauge sender? Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted August 16, 2011 Share Posted August 16, 2011 warmed up idle is normally around 40 and under throttle up to 95. Where did you mount your gauge sender? Rear oil galley mount. Don't like the filter adapter mounts. It was a beeeatch so I am quite content to leave it there. Link to comment Share on other sites More sharing options...
Nrw Posted August 16, 2011 Share Posted August 16, 2011 Mine is usually at about 20psi idle, cold or highway 80-90psi. I have my low pressure alarm set for 15psi. Could be your gauge is off. Also don't run a supposedly thin oil like Mobil 1 either. same Link to comment Share on other sites More sharing options...
MrHellrais3R Posted August 16, 2011 Share Posted August 16, 2011 the rear galley is ideal for these engines. Link to comment Share on other sites More sharing options...
AmSnow440 Posted August 16, 2011 Share Posted August 16, 2011 Mine is usually at about 20psi idle, cold or highway 80-90psi. I have my low pressure alarm set for 15psi. Could be your gauge is off. Also don't run a supposedly thin oil like Mobil 1 either. Same as well. My gauge reads about 20 PSI at warm idle and about 80-90 PSI at highway speeds. I have the sender mounted on an oil filter sandwich plate, and I'm running Rotella T6 5W-40. Link to comment Share on other sites More sharing options...
WileyKyle Posted August 17, 2011 Author Share Posted August 17, 2011 We mounted the sender in place of the stock pressure sender. No codes are popping up, but the turbo is making a wining noise when it spools. Got to almost 80psi on the highway today. Link to comment Share on other sites More sharing options...
dmanaenk Posted August 17, 2011 Share Posted August 17, 2011 Spec is 14+ psi @600rpm, 43+ psi @5k rpm. 666 Link to comment Share on other sites More sharing options...
Biggu Posted August 17, 2011 Share Posted August 17, 2011 Same as well. My gauge reads about 20 PSI at warm idle and about 80-90 PSI at highway speeds. I have the sender mounted on an oil filter sandwich plate, and I'm running Rotella T6 5W-40. this on my car as well. Link to comment Share on other sites More sharing options...
dmanaenk Posted August 17, 2011 Share Posted August 17, 2011 Shouldn't be seeing 90s, since relief valve is set @85psi. It's probably gauge's error though. 666 Link to comment Share on other sites More sharing options...
1SIKLGT Posted January 9, 2015 Share Posted January 9, 2015 I wonder if I'm on borrowed time http://tapatalk.imageshack.com/v2/15/01/09/15bc27e0ec95eb2168b730d4bbedbc58.jpg 8° weather. 10psi idle. 400mi before oil change is due. Usually idles at 15-20psi. And maxes at 40-45psi at wot. Link to comment Share on other sites More sharing options...
frank_ster Posted January 9, 2015 Share Posted January 9, 2015 The 45 psi at rpm is scary . Anything happen to the car ? Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
ras06LGT Posted January 9, 2015 Share Posted January 9, 2015 I've got my sender mounted under the alternator at the stock switch location. Warm idle I'm around 20-22 psi, and 75-80 psi cruising on the highway. 45 psi at WOT and high RPM would worry me a little bit, although it's technically within Subaru's spec. Maybe it's an early sign of pickup tube failure. Link to comment Share on other sites More sharing options...
1SIKLGT Posted January 9, 2015 Share Posted January 9, 2015 I'll probably start with an oil pick up...see if it gets better. Car has 117k, nothing has happened to the car...although it was involved in a fender bender 2 summers ago. Got hit from the rear. Maybe the impact damaged the pick up tube?? Link to comment Share on other sites More sharing options...
4thgengt Posted April 16, 2015 Share Posted April 16, 2015 New to subarus.. My car idlels at 80 psi cold and goes down to around 40 at warm idel Is that normal? Link to comment Share on other sites More sharing options...
frank_ster Posted April 16, 2015 Share Posted April 16, 2015 ^ yep The hot idle oil pressure seems a bit high. Are you running recomended grade of oil ? Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
4thgengt Posted April 17, 2015 Share Posted April 17, 2015 Im running 5w-30 full synthetic but a couple people have recomended a semi synthtic blend Link to comment Share on other sites More sharing options...
TimmyMo Posted April 21, 2015 Share Posted April 21, 2015 Does anyone have any pics or walk throughs of a oil pressure sending unit install? I'm about to install an oil pressure and an oil temp gauge and it would really help. Cheers! Link to comment Share on other sites More sharing options...
WRX USA Posted April 21, 2015 Share Posted April 21, 2015 Does anyone have any pics or walk throughs of a oil pressure sending unit install? I'm about to install an oil pressure and an oil temp gauge and it would really help. Cheers! http://techinfo.subaru.com/proxy/50471/pdf/050471-H5010AG000139242.pdf Link to comment Share on other sites More sharing options...
TimmyMo Posted April 21, 2015 Share Posted April 21, 2015 Thanks a lot! That helps a lot! Do you know where to tie in the sending unit(s) of you don't want to use a sandwich adapter? Link to comment Share on other sites More sharing options...
JJr Posted April 21, 2015 Share Posted April 21, 2015 Why not use a sandwich adapter? What gauge/s are you using? Link to comment Share on other sites More sharing options...
frank_ster Posted April 21, 2015 Share Posted April 21, 2015 If you want oil pressure the oil pressure switch is next to the altenator you could just install a tee if you want oil light and oil pressure. Oil trmperature you could install in the oil pan Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
