cnylegacy06 Posted July 8, 2018 Share Posted July 8, 2018 Help needed ! -- I have no codes, new radiator, new water pump, new thermostat, new rad cap, runs at idle does not overheat. As soon as I drive down the road in less than 5 minutes, temp rises ! ? Prior to this I did replace head gaskets. Can it be possible that exhaust gas is still breaching through the gasket into the coolant with-out a miss-fire and no codes ?? Frustrating........... Any and all replies are welcome 2006 Subaru Legacy with 120k Link to comment Share on other sites More sharing options...
Infosecdad Posted July 8, 2018 Share Posted July 8, 2018 OEM Thermostat and Radiator Cap? Highly recommend OEM only for those and make sure the thermostat isn't in backward. Also, could just be air in the system that hasn’t been burped out yet. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 8, 2018 Share Posted July 8, 2018 X2 for burping the system. Raise the right front corner of the car as high as you can, remove the radiator cap on turbo coolant tank, start the engine. watch for air bubbles in the tank, may be squeeze the top radiator hose, turn on the heat to high. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cnylegacy06 Posted July 9, 2018 Author Share Posted July 9, 2018 Rad cap & thermostat - aftermarket and the thermostat is one of those kind that stays open all the time ! - could that be the culprit ? Why should thermostat be in backwards...? Please explain. Thx Have "burped" car 2x with front end up and funnel technique - I could do it again...? Link to comment Share on other sites More sharing options...
Max Capacity Posted July 9, 2018 Share Posted July 9, 2018 Most of us recommend only a OEM thermostat. I did replace both radiator caps a couple years back again only OEM Next would be to have a repair shop with a HC tester see if your getting exhaust gas's in the coolant system. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
08SpecB_DE Posted July 9, 2018 Share Posted July 9, 2018 Make sure there are no leaks as well. When I did my TB, I slightly punctured the 90° heater hose and it was able to suck air into the system. Link to comment Share on other sites More sharing options...
Infosecdad Posted July 9, 2018 Share Posted July 9, 2018 Rad cap & thermostat - aftermarket and the thermostat is one of those kind that stays open all the time ! - could that be the culprit ? Why should thermostat be in backwards...? Please explain. Thx Have "burped" car 2x with front end up and funnel technique - I could do it again...? Sorry, check to make sure the thermostat ISN'T backward... Aftermarket thermostats and caps are fairly well known in the Subaru circles to cause problems. Even brand new ones. I've always had to burp by squeezing the upper hose until I get no more bubbles. Sometimes it takes several rounds. Link to comment Share on other sites More sharing options...
cnylegacy06 Posted July 10, 2018 Author Share Posted July 10, 2018 Thanks for all the replies Update - I did the HC test and it was positive - so now the tear-down again to do the head gaskets, not sure which side has the leak so I've decided to do both. Will post results after successful re-start. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 10, 2018 Share Posted July 10, 2018 Make sure the machine shop cleans up the decks on both heads. We recommend ARP head studs too. Is this a GT or a 2.5i ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cnylegacy06 Posted July 11, 2018 Author Share Posted July 11, 2018 Regular - 2.5i Link to comment Share on other sites More sharing options...
Max Capacity Posted July 11, 2018 Share Posted July 11, 2018 yea, 2.5i's are known for HG issues. Nothing new. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cnylegacy06 Posted July 12, 2018 Author Share Posted July 12, 2018 Update --- successful restart and road tested yesterday ! Burped it 2x and good to go. Drove it for about 30 miles and the temp was steady in the middle of the gauge, heck at one point driving through a shaded area, temp went down ! - it was about 80 degrees outside yesterday. Thanks to all who replied I learned a lot and got lucky without a warped head.... Link to comment Share on other sites More sharing options...
