Kellen11 Posted September 18, 2018 Share Posted September 18, 2018 At first I thought it was a boost leak. Then I thought it was an exhaust leak. Been chasing this screech noise under full boost for 3 months now. My only logical conclusion is it’s the famous waste gate crack. What should I do from here? How much power am I losing? Link to comment Share on other sites More sharing options...
JmP6889928 Posted September 18, 2018 Share Posted September 18, 2018 None. Virtually all IHI turbos have wastegate cracks in them. Unless it's all the way up to the gasket surface, you aren't losing any boost. Link to comment Share on other sites More sharing options...
seanyb505 Posted September 18, 2018 Share Posted September 18, 2018 Your post doesn't sound like you've proven it has a crack, just that it's a conclusion you've come to. Have you laid eyes on the crack? Link to comment Share on other sites More sharing options...
subydrift Posted September 22, 2018 Share Posted September 22, 2018 I had a pretty gnarly screech/whistle under boost and it was my lower up-pipe gasket. I took the whole exhaust apart, cleaned all the surfaces and put new gaskets in torqued to spec and it hasn’t made the sound since. Link to comment Share on other sites More sharing options...
Kellen11 Posted September 23, 2018 Author Share Posted September 23, 2018 Is there supposed to be a gasket where the intercooler meets the turbo? I might also check my exhaust Link to comment Share on other sites More sharing options...
Carlz0r Posted September 23, 2018 Share Posted September 23, 2018 From memory, there is an o-ring seal on the turbo side of the TMIC. Link to comment Share on other sites More sharing options...
Kellen11 Posted September 23, 2018 Author Share Posted September 23, 2018 From memory, there is an o-ring seal on the turbo side of the TMIC. Hmm yeah I don’t have one of those. Link to comment Share on other sites More sharing options...
Carlz0r Posted September 23, 2018 Share Posted September 23, 2018 You'll need part 7 from this page. If you're missing it, that could very well be your whistling problem, which would also mean your car is running richer than it should be (due to MAF reading more air than is actually reaching the engine). Link to comment Share on other sites More sharing options...
Kellen11 Posted September 24, 2018 Author Share Posted September 24, 2018 You'll need part 7 from this page. If you're missing it, that could very well be your whistling problem, which would also mean your car is running richer than it should be (due to MAF reading more air than is actually reaching the engine). I can’t seem to find a link to purchase the gasket Link to comment Share on other sites More sharing options...
JmP6889928 Posted September 24, 2018 Share Posted September 24, 2018 Put this gasket between the intercooler and the turbo and you'll never have another leak. It's reusable forever. https://www.summitracing.com/parts/mrg-738g?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-mr-gasket&gclid=CjwKCAjw85zdBRB6EiwAov3RigT4jTYSjj5LsczWhtbCZLtl4NIUwOF-3SZYmtQY8ExR2Y5X4UE_ERoC-gUQAvD_BwE Link to comment Share on other sites More sharing options...
JF1GG29 Posted September 25, 2018 Share Posted September 25, 2018 At first I thought it was a boost leak. Then I thought it was an exhaust leak. Been chasing this screech noise under full boost for 3 months now. My only logical conclusion is it’s the famous waste gate crack. What should I do from here? How much power am I losing? Gnarly screeching at near full boost = most likely compressor wheel contact with housing. How is the play in the shaft? If you have a boost gauge, you can indirectly verify this by watching your peak boost. Since contact with the housing adds friction, the turbo will not build to peak boost, maybe missing it by 2 or 3 psi. If it is this, start planning your turbo replacement. Link to comment Share on other sites More sharing options...
