ashwinearl Posted November 8, 2020 Share Posted November 8, 2020 (edited) JMP modified VF40 70k Miles on it *SOLD* $250 + shipping from NY 13413 This is a JmP6889928 VF40 taken off my 2005 Legacy GT wagon. I purchased it new from JMP. It was replaced with a JMP VF 52. Pics attached: Here is the description JMP provided when I bought it: VF40 that will make it more reliable and much stronger in the boost department. I build a custom version that uses upgraded and modified internal parts-journal bearings, thrust plates, and much better than OE piston ring seals and then I use an aggressive extended tip custom billet compressor wheel that weighs half of the stock wheel and is capable of producing 20+ psi of boost.* I use new inconel turbine/shaft assemblies and then send the entire shaft/wheel assembly for dual plane balancing which is far better than the OE uses.* I do some polishing on the inside of the compressor housing and compressor backing plate. Edited November 20, 2020 by ashwinearl Link to comment Share on other sites More sharing options...
MiniStiGuy Posted November 9, 2020 Share Posted November 9, 2020 Any shaft movement? OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
JJr Posted November 9, 2020 Share Posted November 9, 2020 Shaft movement? It's a JmP!! Link to comment Share on other sites More sharing options...
Supernyamo Posted November 9, 2020 Share Posted November 9, 2020 Interested Link to comment Share on other sites More sharing options...
ashwinearl Posted November 11, 2020 Author Share Posted November 11, 2020 Interested To anyone interested. I am not sure my replies to PMs are going out. My sent folder shows 0 message. contact me directly ashwinearl@gmail.com for shipping estimate 18lbs from NY 13413 USPS 12x12x12 box Thanks Link to comment Share on other sites More sharing options...
seanyb505 Posted November 11, 2020 Share Posted November 11, 2020 You have to manually select "Save a copy of this message in your Sent Items folder." from the "Go Advanced" reply screen. Just quick replying to an incoming PM won't show that option. Unless you're already doing that, then glws! Link to comment Share on other sites More sharing options...
MiniStiGuy Posted November 14, 2020 Share Posted November 14, 2020 I may pick this up from you pending the inspection on my stock turbo OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
armypilot Posted November 20, 2020 Share Posted November 20, 2020 message sent to your above email Link to comment Share on other sites More sharing options...
