jcamacho16995 Posted January 1, 2018 Share Posted January 1, 2018 Hello all, I have a 1994 RHD wagon that doesn't seem like it was very well taken care of. I did drive it 50 miles, but a couple of the issues I'm curious of at the moment are a complete lack of console lights working, including radio, and all the climate control switches. The speedometer also doesn't work, though I haven't tried lubricating it yet. According to the gauges the car also never reaches operating temperature so it seems like the thermostat might be stuck open. Anyone else have this issue? Oh and none of the windows work, I read something about a fusible link somewhere but now I can't find it. Seems like it should be an easy issue to fix, hope it is anyway. Thanks in advance! Link to comment Share on other sites More sharing options...
Smithcraft Posted January 3, 2018 Share Posted January 3, 2018 That's quite a list of issues! I would suggest that you try Legacy Central, as they are primarily a first gen Legacy site. SC 1994 Legacy MI 2008 Legacy GT specB 2023 Crosstrek Limited Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 4, 2018 Share Posted January 4, 2018 The fusible link is in the fusebox in the engine bay. Link to comment Share on other sites More sharing options...
snederhiser Posted January 16, 2018 Share Posted January 16, 2018 Hello; The main fuse box is on the drivers side inner fender and the fuseable link is in there. I think that is for the alternator. On the inner lower cowl panel, driver's side is the fuse block for the lights and such. Pull the main window switch on the drivers door and check it for voltage and ohms, Steven. Link to comment Share on other sites More sharing options...
snederhiser Posted January 16, 2018 Share Posted January 16, 2018 Hello; Not sure of the locations on a RHD, Steven. Link to comment Share on other sites More sharing options...
jcamacho16995 Posted February 10, 2018 Author Share Posted February 10, 2018 Haven't been on in a while but I finally have a chance to get back to it. I'll check to see what I can find. Thanks for the advice guys! Link to comment Share on other sites More sharing options...
Omega79 Posted February 18, 2018 Share Posted February 18, 2018 Another thing to note is the 1st gens had terrible grounds. Put in a set of good ground wires throughout to help phantom issues and dim lights. Climate control had issue with cold solder joints, just take it out and apart, reflow all the joints and may fix your issue. Link to comment Share on other sites More sharing options...
