MGT's 2012 Legacy GT Build
Welp. Bought the car in 2016 and 4 years later finally decided to splurge and make the car as good as I can thanks to all you wonderful folks and this forum. I also replaced transmission 3rd-4th synchro's and shift fork during this time.
Build
Engine Mods
New Sti Crankshaft
New Sti Exhaust Camshafts
Sti Valve Springs/Retainers
Manley Pistons 99.5mm 8.5:1 & H-Beam Rods
King Race Rod & Main Bearings STD
ARP 11mm Head Studs
Sti Thermostat
IAG TGV Deletes
New 11mm Oil pump
Fueling Mods
ID 1050 Injectors
AEM 50-1215 High Flow 340LPH Fuel Pump
Turbo Mods
BNR 18G Turbo
Cobb FMIC Kit (2011-2014 WRX)
GFB MACH 2 TMS Recirculating BOV
GrimSpeed 3-Port EBCS (2015-2018 WRX)
Gauges / Sensors
AEM 30-0300 Wideband Gauge
AEM 30-4406 Boost Gauge
AEM 30-4401 Oil Pressure Gauge
Cobb 315650 Fuel Pressure Sensor
Suspension
Koni Yellows with H&R Springs
Whiteline Front & Rear Sway Bar Kit - BSK015
New Sparco DRS Wheels W/ Continental True Contacts Tour Tires (Stock Size)
Misc
Invidia Q300 Turbo Back Exhaust W/ High Flow Cat.
SouthBend Stage 2 Clutch
Torque Solution Billet Clutch Fork
Verus Engineering Billet Clutch Fork Pivot
Clutch Damper Valve Delete
Perrin Brass Shifter Bushing
Perrin Shifter Stop
Perrin Short Shift Adapter W/ Sti STS
Primitive Racing Skid Plate
Media
Suspension Setup
Intercooler mock up - Had to use spacers for crash bar and cold side was tight, but didn't have to cut anything other than the bumper.
Final product - Bumper already beat up after 150k miles so I didn't mind hacking it up a bit to fit the piping.
Engine bay - Might get SD tuned in the future and do away with the ugly recirc hose. Also have to tidy some things up. Functional for now though.
Gauge Setup - Had to use tiny flat head bolts to secure them to the top of the climate control. Might come up with some sort of bezel for a cleaner look in the future.
Case Halves with old crank - Thanks for the workbench @GTEASER
New crank, pistons, heads, studs... All together.
Trans was kind of tricky, but next time shouldn't be as bad.
I definitely skipped over some things, but just figured I'd share the major steps and interesting parts. Just about everything pictured was done throughout this year. Still in engine break in, but the engine, trans and suspension changes all seem to be working well.
This is a great car regardless of what's been done to it.
Edited by MGT
