Killuminati206 Posted March 21, 2017 Share Posted March 21, 2017 OK so my passenger fender has glue all over it. I got a new one. Could not find any write ups on how to remove . Is this a difficult task. Please help. Thanks Link to comment Share on other sites More sharing options...
WRX USA Posted March 21, 2017 Share Posted March 21, 2017 ^ I'm pretty sure you'll have to take off the front bumper to remove your headlights. Link to comment Share on other sites More sharing options...
Killuminati206 Posted March 21, 2017 Author Share Posted March 21, 2017 - Pop your hood, with something other than the rod in the car as it is attached to the fender you will be removing. - Disconnect the battery, - Take out the air intake funnel. - Unscrew the bolts from the top of the fender in the engine bay - Unscrew your headlights and grill - Move under the car and remove the pop-its from the passenger side fender liner. - Pull the front bumper off to access the screws under the bumper. Pull the side skirt off and un-screw the bolts that were under the side skirt. Open the door and unscrew the one bolt holding the fender in place and start pulling it up and way from the car. Thanks. Not looking forward to this Link to comment Share on other sites More sharing options...
Killuminati206 Posted March 21, 2017 Author Share Posted March 21, 2017 Where's the bolt when you open the door?? Link to comment Share on other sites More sharing options...
