cobb Posted July 28, 2013 Share Posted July 28, 2013 So being in the military I wait in very long lines to get in the front gate, my car is a 5eat so when I just let of pf the brake the car starts to roll then starts shuttering and the rpms drop, when I stop it stops, when I accelerate it stops, it's only when I drive very slow it starts to shutter. I cleaned the maf, cleaned my air filter, changed mostly every vacuume line I can and also put I'm some fuel Injector cleaner. Anyone had this issue? Link to comment Share on other sites More sharing options...
cobb Posted July 29, 2013 Author Share Posted July 29, 2013 Nobody else has seen this issue? Link to comment Share on other sites More sharing options...
bclegwagon Posted July 29, 2013 Share Posted July 29, 2013 Had this same issue with my wife's car for over a year. Did all the things you did, still didn't do anything. Took it in and had the transmission fluid flushed, never had it happen again. How long has it been since you have changed it, would be the question. Link to comment Share on other sites More sharing options...
cww Posted July 30, 2013 Share Posted July 30, 2013 Is it stuttering when you're on gas pedal or off or both? Mine used to stutter while coasting down (clutch engaged, but off the gas / throttle closed) at slow speeds in 1st or 2nd gear only. I have a 6MT. I just flashed my car to Cobb AP Stage 1 and this problem went away. But I've heard of people having the dealer reflash the car's stock map to fix the stutter. Link to comment Share on other sites More sharing options...
SPeC.B_MaZTer Posted July 30, 2013 Share Posted July 30, 2013 By any chance is your air conditioner on? If so, verify it has the same issue when the A/C button is off. A possibility is the compressor may be cycling excessively because of low Freon or an A/C malfunction. Good luck. Link to comment Share on other sites More sharing options...
gear_monkey Posted July 30, 2013 Share Posted July 30, 2013 Shot in the dark but look at all your vacuum lines. I had one that had popped off that I didn't catch for a while. Link to comment Share on other sites More sharing options...
rob-2 Posted July 30, 2013 Share Posted July 30, 2013 This can be so many things. Mine, low compression on 2 cyls Link to comment Share on other sites More sharing options...
cobb Posted July 31, 2013 Author Share Posted July 31, 2013 I drove in a empty parking lot trying to get a code to pop but nothing, it died twice on me yesterday coming to a stop. Sometimes it will start up but already be sputtering like the rpms are having a hard time climbing and then it will just click and a go smoothing, not literally click but as if something mechanical is causing it to run like a diesel and then it instantly runs smooth Link to comment Share on other sites More sharing options...
cobb Posted July 31, 2013 Author Share Posted July 31, 2013 Also a/c on or off it still does it Link to comment Share on other sites More sharing options...
cobb Posted July 31, 2013 Author Share Posted July 31, 2013 Problem solved, the k&n intake was cousins this issue. With the stock air box back on the car ran perfectly Link to comment Share on other sites More sharing options...
Max Capacity Posted July 31, 2013 Share Posted July 31, 2013 Oh so the car was not tuned for the intake... The stock intake is good for lot's of HP. Most of us keep it. Having said tuned, is your car on the stock MAP ? If yes, you'll want to fix that. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cobb Posted August 1, 2013 Author Share Posted August 1, 2013 Yes the car came with a v1 acessport stage2 tune so I assumed it had a intake on it with the original owner because it came with a Cobb dp but looked like the exhaust and stock air box had been removed then re installed for the sale because they both looked brand new Link to comment Share on other sites More sharing options...
iNVAR Posted August 1, 2013 Share Posted August 1, 2013 Wait, so you're running a Stage 2 OTS tune with stock hardware? Uh.... Link to comment Share on other sites More sharing options...
rob-2 Posted August 1, 2013 Share Posted August 1, 2013 Problem solved, the k&n intake was cousins this issue. With the stock air box back on the car ran perfectly This was critical info you didn't provide. Yes the car came with a v1 acessport stage2 tune so I assumed it had a intake on it with the original owner because it came with a Cobb dp but looked like the exhaust and stock air box had been removed then re installed for the sale because they both looked brand new You need at minimum a a gutted downpipe, preffered a catless or highflow cat 3inch to run stage 2. Link to comment Share on other sites More sharing options...
cobb Posted August 2, 2013 Author Share Posted August 2, 2013 It did have a Cobb dp catless when I purchased the car so the tune was fine only thing I really needed was the cat back Link to comment Share on other sites More sharing options...
