What is this part?
Car: 07 LGT 5MT
Found this plastic disk in-line on the BOV, in the bypass line. It almost looks like a restrictor of some sort? When I first got the car, the tubing was relatively loose, so I zip-tied the ends, but didn't notice that it was different.
The same line from my 05 doesn't have it, and I can't seem to find any pictures or info about it here or online - haven't seen it on any other car.
I have the lines (and the BOV) from the 05, so if I don't find anything about it, I'll just remove it and replace the line if necessary, but I'm curious if it has a purpose.
Good thought. Could check by blowing into either end of it. No clue why someone would put one on the BPV reference line though
I thought of this too, and it passes air in both directions - and agreed, why there?
I’m thinking “hose too short, slap on a connector” makes the most sense, the engine is otherwise stock.
