HansGT Posted August 2, 2011 Share Posted August 2, 2011 Picked up some Valvoline Racing Synthetic (VR1) motor oil when they had the $50 rebate promotion. Anyway....it is 10W-30 weight (no 5W-30). Anyone think I'll have a problem with this during summer months? Its been above 90 here in MD for the past month....was going to make the switch over soon. I'm guessing I'd be ok.....thoughts. http://www.valvoline.com/products/brands/racing/racing-motor-oil/8#b Link to comment Share on other sites More sharing options...
Kevin03045 Posted August 3, 2011 Share Posted August 3, 2011 Im using Dino 10w-40 summer & 10w-30 winter no issues. Link to comment Share on other sites More sharing options...
AZP Installs Posted August 3, 2011 Share Posted August 3, 2011 I wouldn't run a 10 weight in the winter but summer it's ok with higher ambient temps the 10 will flow ok. -mike Link to comment Share on other sites More sharing options...
GTTuner Posted August 3, 2011 Share Posted August 3, 2011 I wouldn't run a 10 weight in the winter but summer it's ok with higher ambient temps the 10 will flow ok. -mike 10W would be OK in winter as long as it is a full synthetic. Dino oil may be a different story though. Link to comment Share on other sites More sharing options...
AShoe Posted August 3, 2011 Share Posted August 3, 2011 I won't comment on oil flow, but the high zinc/phosphorus levels in the oil will damage your oxygen sensors and cats if your car uses any oil. Link to comment Share on other sites More sharing options...
bluesubie Posted August 5, 2011 Share Posted August 5, 2011 Many people run 5W-40 in the summer and it is actually thicker at start-up than most 10W-30's. A first number of zero or five does not mean that an oil is thinner than one with a 10. To get a better idea of actual start-up thickness, you'll need to find the CCS/MRV numbers. Your owner's manual, which shows a tempurature chart and oil recommendations for conventional oil, states that you can use 10W-30 and 10W-40 in temps. down to -4F. -Dennis Link to comment Share on other sites More sharing options...
Kevin03045 Posted August 9, 2011 Share Posted August 9, 2011 correction for my fat fingers 10w 40 summer & 5w 30 winter Link to comment Share on other sites More sharing options...
rao Posted August 9, 2011 Share Posted August 9, 2011 Subscribed Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
bluesubie Posted August 31, 2011 Share Posted August 31, 2011 This stuff is thicker than I thought it would be in the cold. Viscosity at 0C/32F. Mobil1 High Mileage 10W-30 = 779.5 Centistokes Mobil1 0W-40 = 563.3 VR1 10W-30 = 815.1 RT6 5W-40 = 710.9 And at 10C/52F M1 HM 10W-30 = 386.8 M1 0W-40 = 307.4 VR1 10W-30 = 396.3 RT6 5W-40 = 377.9 http://www.widman.biz/English/Calculators/Graph.html Didn't want rao to subscribe for nothing. -Dennis Link to comment Share on other sites More sharing options...
johnAWD Posted August 31, 2011 Share Posted August 31, 2011 I use 0w30 year round in Wisconsin, did the same while in Colorado. Link to comment Share on other sites More sharing options...
bluesubie Posted August 31, 2011 Share Posted August 31, 2011 GC = 507.6 at 0C 276 at 10C. I won't even look up M1 0W-30 since it shears to a 20 weight just from shaking the bottle. And at 30c/86f RT6 = 135.2 GC = 101.6 VR1 = 123.6 M1 0W40 = 113.4 -Dennis Link to comment Share on other sites More sharing options...
