minsu900515 Posted December 12, 2019 Share Posted December 12, 2019 Hi all. I have check engine light on and AT oil temp blinking on my 2006 2.0GT JDM spec b. I have had the codes read and it showed the following.. B0201 - CAN-HS COUNTER ABNORMAL B0202 - CAN-HS BUS OFF B0223 - CAN-HS VDC/ABS NO-RECEIVE DATA U1202 - CAN-HS BUS OFF (fault location: Comm.Line Failure(ECM/VDC/ABS to Uint) or Integ. Unit Failure) U1223 - CAN-HS VDC/ASB no-receive data (fault location: Comm.Line Failure(VDC/ABS to Integ. Unit or VDC/ABS Failure) I have checked for lose connections and tried switching ECU, TCU but still having the same code.. Can anyone please give me advice on what to check and where to check for lose connections? Thanks in advance. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 14, 2019 Share Posted December 14, 2019 http://people.csail.mit.edu/ilh/vacation/ Here's the service manual. Hopefully you have this fixed by now. Can you give us more info about the car ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
minsu900515 Posted December 15, 2019 Author Share Posted December 15, 2019 http://people.csail.mit.edu/ilh/vacation/ Here's the service manual. Hopefully you have this fixed by now. Can you give us more info about the car ? Hi what sort of info would you like? It is 2006 JDM spec b with 170k kms. Just one day I was driving to work on the highway and suddenly the check engine light came on and AT OIL TEMP started flashing out of nowhere. Sometimes when I start the car the AT OIL TEMP light is off but comes on again after 3-6 minutes of driving, but most of the time it is instantly flashing when I start the car. Sometimes the VDC warning light comes on every 5min or so. Would be much appreciated if I could get some advice. Thank you Link to comment Share on other sites More sharing options...
Max Capacity Posted December 16, 2019 Share Posted December 16, 2019 JDM, sounds like your not in the USA. I assume you have performed the transmission fluid service and made sure the level is fine ? In the Tranny Forum here you might be able to contact HEXMODs, PM him and see if he has any ideas. Good LUCK, I'm just trying to get someone to see this thread... You can find him here, https://legacygt.com/forums/showthread.php/5eat-ask-your-questions-185412.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
